Strange character on input numbers [SOLVED]
Site Admin
Re: Strange character on input numbers
Postby wmayer » Fri Jan 29, 2016 5:31 pm
Do you get the strange character for any input field or only for the one of the screen shot? And when you execute this snippet below do you get also strange characters or normal input?
from PySide import QtGui
s=QtGui.QDoubleSpinBox()
s.setValue(1.5)
s.show()
And what happens with?
ui=FreeCADGui.UiLoader()
q=ui.createWidget("Gui::QuantitySpinBox")
q.setProperty("unit","mm")
q.show()
Then it would also a bit of help to identify the ASCII code of the characters:
t = "..." # set here the text with copy&paste
for i in t: print (ord(i))
And to get some information about your locales you could try this:
from PySide import QtCore
loc=QtCore.QLocale.system()
loc.country()
loc.language()
loc.measurementSystem()
loc.negativeSign()
loc.toString(1.5)
oldsphere
Postby oldsphere » Mon Feb 01, 2016 8:48 am
Hi wmayer,
Answering your questions, yes, the problem is with all the menus, not just the one on the screenshot.
wmayer wrote:Do you get the strange character for any input field or only for the one of the screen shot? And when you execute this snippet below do you get also strange characters or normal input?
s.setValue(1.5)
s.show()
q.show()
Both codes result in this incomprehensive characters (attached images)
t = "١,٥٠"
[ord(nt) for nt in t]
[217, 161, 44, 217, 165, 217, 160]
wmayer wrote: And to get some information about your locales you could try this:
loc.country()
loc.language()
loc.negativeSign()
loc.toString(1.5)
The information resultant from this test is:
country: PySide.QtCore.QLocale.Country.Spain
negativeSign: -
meassurementSystem: PySide.QtCore.QLocale.MeasurementSystem.MetricSystem
toString(1.5): u'\u0661,\u0665'
Hope this can be useful for solve the problem! Thank you for help.
oldsphere
Postby oldsphere » Tue Feb 09, 2016 8:15 am
Hello folks,
Is there anything else I can try to solve this issue? Any idea will be welcome.
mario52
Postby mario52 » Tue Feb 09, 2016 9:54 am
Hi
just to know
is that in a macro display is the same ?
example Macro_FCCircularText (here text and number)
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
oldsphere
Postby oldsphere » Tue Feb 09, 2016 10:15 am
Hi mario52,
I've tried your macro and the numbers are displayed well on the geometry. The problem is just with the numbers appearing on the menus.
Site Admin
Postby wmayer » Tue Feb 09, 2016 10:51 am
Since also Qt stuff itself is affected it's not a bug in FreeCAD. So, either there are very strange system settings to display numbers or for FreeCAD a strange font can be set. What does this give back?
s.setValue(1.5)
s.show()
f=s.font()
f.family()
oldsphere
Postby oldsphere » Tue Feb 09, 2016 11:06 am
Hi wmayer,
The Qt window shows the same strange charaters.
The font family returns this:
f=s.font()
f.family()
u'MS Shell Dlg 2'
mario52
Postby mario52 » Tue Feb 09, 2016 12:16 pm
hi
and the characters in menus of the macro ?
test Macro_FCInfo_Alternate_Linux the character in the macro mm² mm³ and ° are coded iso8859 just to see the result (select object, Box ... and see)
mario
oldsphere
Postby oldsphere » Tue Feb 09, 2016 12:59 pm
Finally some success! The numbers on the menu are correct, excepting for one on the mass section.
What difference has this field respect to the others?
mario52
Postby mario52 » Tue Feb 09, 2016 2:05 pm
Hi
the mm² are not displayed
the mm ³ are not displayed
the ° are displayed
for the volume is the comma in the spinBox , is the cause
may be your configuration regional or graphic card or encoding .... ?? sorry
mario
