Hi to all,
I searched the forum for keywords clone + placement, but didn't find a related topic.
When I wanted to switch the placements from a part and its clone, the clone doesn't accept placement of the part. Part is a thickness of a cube and has placement 0,0,0 the cube has a placement somewhere else.
I investigated a little bit in an empty document:
- Make a cylinder with part WB, standard-values will do
- Give it placement e.g. 10 mm in x
- Make a clone with draft WB
- Try to give the clone placement 0, 0, 0, click OK and it jumps back to 10, 0, 0. Any other placement will do.
Same with move-tool from draft WB.
I'm using development snapshot, but the same behaviour in 0.15 release.
OS: Windows 8.1
Version: 0.16.6472 (Git)
Hash: a1f16cabec56425f741b12f1d9d2f9e1d0ec61bf
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
[solved] Clone doesn't accept placement 0, 0, 0
- Boneshaker
Monthly FreeCAD Challenge: https://forum.freecadweb.org/viewtopic.php?f=24&t=36615
Re: Clone doesn't accept placement 0, 0, 0
Same problem here but it seems any Placement other than at the origin works.
OS: Ubuntu 14.04.4 LTS
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6456 (Git)
Build type: None
Hash: 9e551e0fdb4321de57471d18a17449e4df0015a6
Python version: 2.7.6
Qt version: 4.8.6
Build type: None
Qt version: 4.8.6
- Boneshaker
Thanks for confirming on Linux.
Knowing of it, it's no big problem. It was strange the clone didn't want to move as I thought.
Maybe it's a bug.
Maybe it's a bug.
You're welcome. I don't think it's a big deal but I can't think of a reason why a Clone shouldn't be at 0,0,0. Nonetheless I cross posted here:
viewtopic.php?f=8&t=11557&p=115651#p115651
- Boneshaker
Thanks very much.
