Ticket #2488: Standard paths issues from import SVG to FreeCAD (was: Ellipse issues imported from SVG files)
EdgarRobles
Post by EdgarRobles »
I found some issues when i was making my CNC box case, It looks like it is something related to ellipse decoding.
OS: Ubuntu 14.04.4 LTS
Version: 0.16.6668 (Git)
Build type: None
Hash: 7dbcbc0f762b1d21abc50e79112a0cf9be97bd47
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Here we have a short test made on Inkscape and result of import to FreeCAD.
1.-I made a draw on Inkscape incluing form that do the issues.
2.- Import as a drawing. (Arrow points does not appear)
3.- Import as a geometry. (Ellipses out of right place and deformed)
Sorry for my bad english.
Original SVG_file.
Bug.svg
(14.02 KiB) Downloaded 104 times
yorik
Founder
Re: Ellipse issues imported from SVG files
Post by yorik »
hm the ellipses are not ellipses anymore in the svg file, they have become standard paths. Nevertheless, they should normally be imported without errors.
I have not enough time these days to look into this, would you mind opening a ticket on the tracker at http://www.freecadweb.org/tracker (you can add a link to this forum thread) so we don't forget about it?
EdgarRobles
yorik
Founder
Post by yorik »
thanks!
bejant
Post by bejant »
issue #2488 as reported by EdgarRobles
blue = edit
Post by Kunda1 »
soft bump
cox
Post by cox »
I can confirm that this is still an issue in :
OS: "Arch Linux"
Version: 0.17.10167 (Git)
Hash: 112749bc97e557b14bf16c216bf012915975e22d
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.9.1
renatorivo
Post by renatorivo »
I'm not an expert Inkscape, but after some changes in Inkscape there have been improvements.
Sure it's a bug? or it depends on how the svg file is created and saved?
Renato
renatorivo
After another workaround, I have all the edges. I think.
Renato
EdgarRobles
I opened bug.svg on inkscape 0.91 and it don't seems any issue but i tried open same file on freecad and it's doing always the same faults
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10168 (Git)
Build type: None
Hash: 6630bcf9fa8e849fe846d1c2b780148a7a2c1e4b
Python version: 2.7.12
