Hi guys,
chrisb wrote: ↑Fri Jul 21, 2017 1:51 pm
Thank you very much for the tip concerning the tip! I must have completely missed it's introduction.
jmaustpc wrote: ↑Fri Jul 21, 2017 2:19 pm
Yeah me too! I didn't at first understand what "Tip" was for either.
I know that ickby mentioned the tip at some point, but it's not in the first post's useful links and I don't remember if he gave details about it anywhere. The idea of the "tip" is that it's the feature that is exposed outside the body. It's a common feature in parametric CAD, although I hadn't seen it called that way. Since I have experience with other parametric CAD software I quickly realized what it was.
In Solid Edge which I use daily (rather a very old version), it's done with a right-click like in FreeCAD, only it's called simply "Go to" rather than "Set tip". When doing that, a counter-clockwise circling arrow icon is added in the tree besides all the elements (sketches and features) below the tip, this is a clear indicator of where the tip is. I think adding a similar visual indicator in FreeCAD would be very useful and potentially avoid confusion and mistakes.
In SolidWorks, there is a very nifty "rollback bar" in SW's version of the Model tree. You drag it from the bottom to some point in the Body tree, and this sets the tip. Below the rollback bar, the features are greyed out to indicate they're inactive. This video displays its use:
https://youtu.be/lD4hcLBS3bM
I think a rollback bar would not work well in FreeCAD because you can have more than one body in a document, which means you would need one rollback bar for each body... In SW as in SE, there are separate file extensions for a part, an assembly or a drawing, so in a part document there is only a single body tree.
At first when PDnext was new a topic here on the forum made a lot of sense, but now I think this would be better as a wiki page so it is easier to keep it concise and accurate.
Hello Renato, your sandbox page has been very useful over the past 15 months since PDN was merged to master. But there are more and more people starting to test and use the 0.17-dev builds, and I think we're at a point now that we should think about extracting the content from the Sandbox page and start creating separate page tools, etc.
@Jim
Glad to know that Kristoff Wally Norman Steve is alive, well and kicking!
