FC v0.17dev: Part Design Next Usecases and Best practices
Re: FC v0.17dev: Part Design Next Usecases and Best practices
schupin wrote: Mon Apr 23, 2018 9:23 pm (I only know how to pick a edge from another sketch as a reference, not a point :()
It is exactly the same process: Click the ExternalGeometry icon and then click an external point - instead of a line.
schupin
Post by schupin »
chrisb wrote: Mon Apr 23, 2018 11:10 pm It is exactly the same process: Click the ExternalGeometry icon and then click an external point - instead of a line.
Oh :)
Thank you Chrisb, I've never noticed the yellow highlight on the points !
(and on my french version, the tooltip on the ExternalGeometry icon says that's for creating an edge)
guillaumec
Post by guillaumec »
Question from a relatively new user concerning the new part design:
I am working on a casing model with many small parts. Is it better to work in a single body part and add pads/pockets into it, or to make several sub bodies merged by boolean operations?
I started by using the first method in order to keep my tree view relatively clean, but one problem is that as my model grows more complex it becomes quite slow to edit because of the re computation. I am now tempted to restart the model only using boolean operations so that I can work on parts in isolation.
I attach a screenshot that shows the two approaches on a test model.
Screenshot from 2018-04-26 12-58-48.png (61.17 KiB) Viewed 1906 times
Any thought on that?
HarryGeier
Post by HarryGeier »
Well,
i would have done that in a more simple way:
Create a base sketch,
Pad outer shape of bottom
Pad shape of walls
Pad shapes of separators
probably all based on a set of parameters from s worksheet or master sketch.
finally fillet the corners..
Kaum macht man´s richtig , gehts´s
My Video Tutorials on Youtube: https://www.youtube.com/channel/UCoe3B ... p8Q/videos
My FreeCAD Stuff on Hidrive: https://my.hidrive.com/share/qr3l1yddy6#$/
guillaumec wrote: Thu Apr 26, 2018 5:00 am I am working on a casing model with many small parts. Is it better to work in a single body part and add pads/pockets into it, or to make several sub bodies merged by boolean operations?
It depends. If you want to 3D print you should keep it all in one body, if you want to build it from single pieces (e.g. wood) you should model separate bodies. Use the master sketch technique anyway and import it into your several bodies with a ShapeBinder. There are no boolean operations required.
Your model shouldn't get slow with this rather simple model, perhaps Thickness is the show stopper. You avoid this by going the Harry way.
schupin
Post by schupin »
HarryGeier wrote: Thu Apr 26, 2018 11:48 am Well,
Pad shape of walls
Seemed a good exercice for me to pratice with sheets and master sketch !
I'm quite happy to succeed and have a ligth parametrised file !
ParametricCase.FCStd
(52.31 KiB) Downloaded 116 times
HarryGeier
that´s good !
miniellipse
Post by miniellipse »
Hi schupin,
Would you be so kind as to tell me how did you manage copy lines from the master sketch into your sub-sketches? I took your file and and deleted the green lines in Sketch001 but I do not know how to link the geometry from your Master (sketch). The button, "Copies the geometry of another sketch (C,C)" does not seem to do anything. I'm using:
OS: Windows 7
Version: 0.17.13515 (Git)
Branch: releases/FreeCAD-0-17
Hash: e17b340949b75a226cc7d89989b0aa238ccfc75f
Python version: 2.7.14
OCC version: 7.2.0
thank you for your help.
miniellipse wrote: Thu May 03, 2018 9:06 pm Would you be so kind as to tell me how did you manage copy lines from the master sketch into your sub-sketches?
They are referenced by using "External Geometry". In the "Elements" section of the sketcher's panel to the left there are the elements subsequently numbered beginning from 1. In Sketch001 they are numbered from 1 to 12. These are the non-external elements. Then comes a gap in numbering and then it continues. In Sketch001 it is from 15 to 24, all of them being points here. These are the exernal references. They can be used together with constraints to define the sketch.
If you copy sketches instead of using external references you are breaking the parametricity of your model.
schupin
Post by schupin »
I used "create an edge linked to an external geometry" to link my sketches to the master.
But, like chrisb said before, I just add points from the master geometry (not the complete edge)
schupin wrote: Mon Apr 23, 2018 9:23 pm But I feel stupid, I can't see how you made the link between your master sketch and the others ?
Your sketch001 possesses 2 points with a "red cross" that seemed to be picked from the master sketch. I don't know how you did it ?
EDIT : chrisb , you were faster than me ;)
