How to cut out the object named "3" from the "2" one? The opration failed on my cumputer.
Version: 0.16.6703 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Thread cutting
Thread cutting
- 123.fcstd
- (131.05 KiB) Downloaded 64 times
Re: Thread cutting
Part > Check geometry + BOPCheck shows your Sweep, "3", has geometric SelfIntersect errors out the wazoo. This is because the sweep crosses itself every direction of the compus. To fix this, I fused the outermost "thread" part of the Sweep, (review "3 Sketch" to see the changes) to a Cylinder that was rotated 1* on the Z axis to avoid a coplanar/tangent condition with the edges. I then Cut the fused part from the flange, "2", and it now works. No helical sweep like you have there will ever work, as it folds over on itself.AvgJoe wrote:How to cut out the object named "3" from the "2" one? The opration failed on my cumputer.
Qt version: 4.8.6
Mark
OS: Kubuntu 14.04.4 LTS
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.18-dev
Re: Thread cutting
hi
i have simplified sketch3 EDIT: oups quick61
mario
mario
Re: Thread cutting
Quite alright mario, as with most things FreeCAD, more than one way to get from start to finish. Little different approach, same end result.
Mark
Mark
Re: Thread cutting
Thank you!
Re: Thread cutting
hi quick61
you posted that while I work on the subject (and I did not see your post)
mario
yesquick61 wrote:same end result.
mario
- tanderson69
