hi,
i just want to report why the origin point changed after created a utility to sweep, and then cut that portion:
sample file pls find below:
AS you can see in the file, i exaggerated an origin point of a box NOT in the origin of 0,0,0,
then i make a utility sweep, then boolean deduct the two part, now i have a part where the origin has been reset to 0,0,0, which is not want i want - actually it is ok if it consistent. why because, im goint to use this part to be assembled in another file. If the origin point is not the same, i could not align them.
You see, resulted origin point becomes 0,0,0 but in reality it is not, when i tried to assemble it using Shape.Boundary.getPoint() to another file, the points that i have is not 0,0,0 origin but the previous origin where it was exagerated.
i just want to ask help, how do i keep track of the original origin point???
is there a utility to find this?
thanks so much
origin changed after a cut from a utilility to sweep
YC Stone Natural Stone Supplier
Re: origin changed after a cut from a utilility to sweep
my freecad settings below:
OS: Ubuntu 15.10
Version: 0.16.6703 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
Python version: 2.7.10
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
OS: Ubuntu 15.10
Build type: None
Qt version: 4.8.6
- DeepSOIC
Hi!
Am I correct with understanding what you complain about:
* Placement of Clone of Box is nonzero
* you expected Placement of Cut to be nonzero, but it is zero
This is by design. There are quite a lot of people complaining it makes it hard (almost impossible) to move parts as a whole, together with their original shapes. This is being addressed in development version v0.17, where Part and Body containers were introduced to do this kind of business.
DeepSOIC wrote:Hi!
Hi DeepSoic,
yes that is exactly what i got, i got a nonzero origin but it becomes a zero after the sweep cut. it is OK if the origin changed, but it should be consistent, for example, i transfer the sweep cut part to another file for assembly, the script for the assembly uses the origin point, i get way off the mark after the assembly. as temporary fix, i tried to make the part before the sweep cut to zero-origin, then make the sweep cut. Now i copied this part to another file for assembly, the script for automatic assembly works fine now. note that the script for assembly works something like this:
if '03' in obj[0].Name:
if len(obj)==3:
v1o=obj[0].Shape.BoundBox.getPoint(4) #_03 backcurve
v1e=obj[0].Shape.BoundBox.getPoint(2) #_03
v2o=obj[1].Shape.BoundBox.getPoint(4) #_02l
v2e=obj[1].Shape.BoundBox.getPoint(2) #_02l
v3o=obj[2].Shape.BoundBox.getPoint(4) #_01
v3e=obj[2].Shape.BoundBox.getPoint(2) #_01
v3xl=v3e.x-v3o.x
v1xl=v1e.x-v1o.x
x_dev=(v3xl-v1xl)/2
x=[ v3o.x+x_dev ][0] # gardener is base
y=[ v2e.y-v1e.y ][0]
if v1e.z<>v2e.z:
temp=v1e.z-v2e.z
if v1e.z>v2e.z:
z=[ v1o.z-temp ][0]
if v1e.z<v2e.z:
z=[ v1o.z-temp ][0]
else: z=v1o.z
return x,y,z
the function return x,y,z which is the new placement point of the part. it is still crude. i only need two points (4) front-left-down point, and (2) back-right-up point, to get the part where it is then have the script assemble all the parts. it would be nice if the origin point inconsistency would be solved.
i would like to understand this another way, at first when the part is non-zero origin, its coordinate system is global. After the sweep cut into the part, the origin of part becomes zero, so it means its coordinate system becomes local to the part only. i copy this part to another file, where all it properties have been transferred also, so the local coordinate becomes the global coordinate, but the problem, although the origin coordinate of this part is 0,0,0 it is not actually zero but positioned in the original coordinate before the sweep cut, so it means i got 0,0,0 coordinate but actually it is not. it would be fine if i can call the original coordinate points..Is there a way to call the original coordinate other than call getPoint()????
i havent had a time to compile on my own the freecad, though im using linux, but because its too involved, in the future i think i will. if this somewhat improve in 0.17 i am looking forward for it.
cheers!
sorry the code above is unrecognizable wo the indent, here again
if len(obj)==3:
v3xl=v3e.x-v3o.x
v1xl=v1e.x-v1o.x
x_dev=(v3xl-v1xl)/2
if v1e.z<>v2e.z:
temp=v1e.z-v2e.z
if v1e.z>v2e.z:
z=[ v1o.z-temp ][0]
if v1e.z<v2e.z:
z=[ v1o.z-temp ][0]
else: z=v1o.z
return x,y,z
