Hello,
In order to get flat pieces laser cut, I generally either export a clone of that part that i move in xy plane to dxf, or create a 2D projection as a svg. Albeit a few annoying join/join/join operations in adobe illustrator prior to cutting, it works great
This time i would like to try something different by bending acrylics that is not flat in the 3D model.
For starters, I would like to bend a 3mm acrylic sheet of the outside of this cone :
I was thinking of build a structure, slowly blend a few centimers, get then glued to the structure, and repeat operation until done
but how do I -- in freecad 16 -- convert the outside of the cone to a 2D dxf or svg that I can laser cut ?
I mean i could do the math on paper, create the C-shape 2D part in freecad in order to get the corresponding dxf/svg. But can't freecad do it alone already?
any idea?
thanks
How to generate a 2D plan of the ouside of a cone for laser cuting?
Re: How to generate a 2D plan of the ouside of a cone for laser cuting?
You can try the macro from here: http://www.freecadweb.org/wiki/index.ph ... ed_Surfacefourchette wrote:but how do I -- in freecad 16 -- convert the outside of the cone to a 2D dxf or svg that I can laser cut ?
It is known not to work in some cases, but you could give it a try. I added a function in order to get also circles, but still needs more work. I am considering to write something complete new. Attached is my edited version of the macro.
Ulrich
- unrullRuledSurface2.py.zip
- (7.05 KiB) Downloaded 85 times
- DeepSOIC
I wonder, why does the macro promise (by its title) to unroll any ruled surface, when it seems impossible in general? Hyperboloid, for example, cannot be unrolled.
i can't answer for the marketing name of a macro...
however, in the mean time, i actually made the math to build the 2D plan on a smaller scale, got it printed on paper, built it, measure base diameter and height and.... => it didn't work
now i used the suggested macro, did the same thing and now it works.
ohh well... so much for my ego and thanks freecad community for preventing me from getting stuck
Hey there,
not sure if the macro should work on this piece, but I'd need this lofted surface unrolled. The macro creates lots of elements with errors in groups.
Is there any other way (I haven't found yet) to do this?
They're two differently sized rectangles with rounded corners, one at an angle of 20°.
Did you check the ruled surface parameter when you lofted the profiles?
Hey, thanks for your reply!
I now also added a slit where I want to weld it later.
The macro now creates the correct number of drafts in the right order, but they're not arranged correctly yet (edges 1 to 4 would be the generatrices): I've tried putting them next to each other, but it seems the scale of some is also off: The file in question is attached. It's supposed to become a connector piece for turbocharger flanges (T3 -> T25) for a friend.
Edit: I'm using 0.17 (git 7989 from ppa)
Yes, "ruled" is checked (now - sorry!).Did you check the ruled surface parameter when you lofted the profiles?
- turbo_flange.fcstd
- (156.81 KiB) Downloaded 83 times
