Nurbs editor
microelly2
Re: Nurbs editor
Postby microelly2 » Mon Jan 09, 2017 10:05 pm
triplus wrote: P.S. Looking forward to test the BSpline editor!
here the prototype https://youtu.be/CmhZlU1V46Y
triplus
Re: Nurbs editor
Postby triplus » Mon Jan 09, 2017 11:04 pm
Looking good.
Note that i don't plan to work further on this for now. But i decided to try out if i can get a working prototype to move a representation of the interpolated point of the BSpline on the screen and for the BSpline to update accordingly after. And doing that by using your spreadsheet prototype macro as a base for it:
# version 0.1
from PySide import QtGui
from PySide import QtCore
import FreeCAD,Draft
import  nurbswb.needle
from nurbswb.needle import npa2ssa,ssa2npa
draftPts = []
def updateSS(ss,curve):
   '''update curve data into spreadsheet'''
   ss.clearAll()
   npa2ssa(curve,ss,2,3,(1.0,1.0,0.5))
   ss.set('B1',str(len(curve)))
   App.activeDocument().recompute()
def updateDraft(ss,obj):
   '''update Draft Bspline object points from spreadsheet ss'''
   global points
   cl=int(ss.get('B1'))
   curve=ssa2npa(ss,2,3,4,3+cl-1)
   obj.Points=[FreeCAD.Vector(c) for c in curve]
   points = obj.Points
global writeBack,ss,obj2,points
def writeBack():
   global ss
   global obj2
   updateDraft(ss,obj2)
   Gui.SendMsgToActiveView("ViewFit")
def onApply():
    writeBack()
    for i in draftPts:
        App.activeDocument().removeObject(i.Name)
    del draftPts[:]
    for i in points:
        point = Draft.makePoint(i + obj2.Placement.Base)
        draftPts.append(point)
def onUpdate():
    pts = []
    for i in draftPts:
        pts.append(i.Shape.Point)
    updateSS(ss, pts)
    onApply()
btnApply = QtGui.QPushButton("Apply")
btnApply.clicked.connect(onApply)
btnUpdate = QtGui.QPushButton("Update")
btnUpdate.clicked.connect(onUpdate)
def pressed(index):
   pass
def clicked():
   pass
def undock(ss):
   ''' open the data spreadsheet as top level window'''
   label=ss.Label
   mw=FreeCADGui.getMainWindow()
   mdiarea=mw.findChild(QtGui.QMdiArea)
   ss.ViewObject.startEditing(0)
   subw=mdiarea.subWindowList()
   for i in subw:
      if i.widget().metaObject().className() == "SpreadsheetGui::SheetView":
         sheet = i.widget()
         table=sheet.findChild(QtGui.QTableView)
         print "table found"
         break
#   table.clicked.connect(clicked)
   table.pressed.connect(pressed)
   sws=mdiarea.subWindowList()
   print "windows ..."
   for w2 in sws:
      print str(w2.windowTitle())
      if str(w2.windowTitle()).startswith(label):
         sw=w2
         print "found"
         bl=w2.children()[3]
         blcc=bl.children()[2].children()
         w=QtGui.QWidget()
         w.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
         buttons = QtGui.QHBoxLayout()
         buttons.addStretch(0)
         buttons.addWidget(btnUpdate)
         buttons.addWidget(btnApply)
         box = QtGui.QVBoxLayout()
         w.setLayout(box)
         ss=blcc[3]
         box.addWidget(ss)
         box.insertLayout(1, buttons)
         w.setGeometry(50, 30, 650, 350)
         w.show()
         sw.close()
         return w
# test  case
#create the Bspline
p1 = FreeCAD.Vector(0,0,0)
p2 = FreeCAD.Vector(1,1,0)
p3 = FreeCAD.Vector(0,2,0)
p4 = FreeCAD.Vector(-1,1,0)
Draft.makeBSpline([p1,p2,p3,p4],closed=True)
# extract the data
obj=App.ActiveDocument.ActiveObject
bc=obj.Shape.Edge1.Curve
poles=bc.getPoles()
knots=bc.getKnots()
we=bc.getWeights()
mults=bc.getMultiplicities()
pts=obj.Points
poles
knots
we
mults
# create a d fill the spreadsheet
ss = App.activeDocument().addObject('Spreadsheet::Sheet','Spreadsheet')
updateSS(ss,pts)
# create an other Draft BSpline
p2 = FreeCAD.Vector(10,1,0)
Draft.makeBSpline([p1,p2,p3],closed=True)
obj2=App.ActiveDocument.ActiveObject
# write Points back
# open Spreadsheet
w=undock(ss)
onApply()
Run the macro and after use the Draft Move on BSpline or change some values in the spreadsheet and press Apply button to see points re-created. Or use Draft Move on one of the points and after press on Update button to see spreadsheet and BSpline updated. Note that as for the translations of BSpline i didn't investigate further on how to take care of the rotations and things like that. Creating version with QTimer is just adding few more lines. I didn't publish that as after closing the dialog i would need to take care of removing the timer and things like that first. Not hard to do but out of scope for now from my side.
triplus
Re: Nurbs editor
Postby triplus » Tue Jan 10, 2017 3:20 pm
I had an extra hour of free time today and decided to test the theory out:
viewtopic.php?f=24&t=19772#p152640
microelly2
Re: Nurbs editor
Postby microelly2 » Tue Jan 10, 2017 10:00 pm
I have added some more comfort to the editor and learned more about QTableWidget Events.
https://youtu.be/VyTWMJ5dtpg
It can now be used for Wires and Beziers too.
And I see the possibility to use the Widget for VectorList Properties like Animation Tracks.
triplus
Re: Nurbs editor
Postby triplus » Tue Jan 10, 2017 11:08 pm
Yep this is it.
The level of (engineering) control i do feel comfortable working with on a curve level. This is something i can start using in production environment and get results. Anyway looking back i got the tool i felt suits my needs. And now i guess i will leave you to others and your own visions for a while to progress this and other areas further! And i get to use (and test) the tool should the need arise. ;)
triplus
Re: Nurbs editor
Postby triplus » Fri Jan 13, 2017 1:06 am
@microelly2
I remembered how we where discussing on how to use PieMenu for Nurbs editor purposes. Curve editor clearly shows how that can be achieved. If you would in addition make a few standalone commands on the toolbar like:
  • Edit curve (exposes selected curve points)
  • Toggle poles/knot curve points
  • Move curve point command (select base point and point on a curve)
Such commands can easily be added to PieMenu and the interaction becomes really fast. And as a bonus at the same time current FreeCAD UX interaction paradigm is preserved as the solution doesn't have to be tailored just for PieMenu.
microelly2
Re: Nurbs editor
Postby microelly2 » Fri Jan 13, 2017 9:17 am
triplus wrote:@microelly2
Yes, its not forgotten - I have alredy the "move commands" x y z t n d r as candidates and the workflow then can be pie menu -> direction select -> mouse move for distance and click to commit.
But for the next weeks I need most time to support our CAM project which uses the geodata nurbs to get a terrain model: https://www.youtube.com/watch?v=ajbFLpeI7vk
Konstantin
Re: Nurbs editor
Postby Konstantin » Fri Jan 13, 2017 10:23 am
Hello. It's all impressive, but where can I get this NURBS editor to play with it? I'm lost in this thread and all of it's links :)
And a litle/huge feature request for the future. (Or, maybe explain to me why nobody does it)
I want not NURBS surface, which approximates surface somewhere inbetween control points, I want surface to go strictly thru control points.
Is it so useless, or is it so hard to implement, so nobody does it?
microelly2
Re: Nurbs editor
Postby microelly2 » Fri Jan 13, 2017 11:45 am
Konstantin wrote:Hello. It's all impressive, but where can I get this NURBS editor to play with it? I'm lost in this thread and all of it's links :)
https://github.com/microelly2/freecad-nurbs
It is possible to approximate or interpolate data but the result is not unique
http://freecadbuch.de/doku.php?id=blog: ... roximieren
interpolation of points to a curve is done by the Draft Bspline Method
interpolation of points to a face:
viewtopic.php?f=13&t=15988&start=10
and geodat workbench https://github.com/microelly2/geodata
and there are methods in reverse engeneering wb.
keithsloan52
Import 3DM files with OpenNurbs
Postby keithsloan52 » Fri Jan 13, 2017 12:48 pm
Which reminds me I must get back to development of Importing Rhino 3DM files. Been 3 months since last commit :-(
https://github.com/KeithSloan/FreeCAD_ImportNurbs
