Bunch of issues/questions
NormandC
Re: Bunch of issues/questions
Post by NormandC »
chrisb wrote: I don't know the workflow in other systems but I think you have to learn to think more the FreeCAD way.
+1.
With your last examples it is clear that you are still not really trying to familiarize yourself with FreeCAD, you are trying to do what you're used to in SolidWorks.
efyx
Post by efyx »
This is internet forum which is used to exchange and to share ideas. Your point of view is that is ok as it is, in my point of view would be nice if it wouldn't be limited todo that operation as I posted. Question is not: is it worth of doing that, question is: is it hard to do that and is there someone who would do that? Are you responsible for sketch module? We all wish the best to FreeCAD and that's why we are involved some way (I less/you more - because of your skills). Cheers.
mario52
Post by mario52 »
hi
patience for tomorrow
select twoo or more objects Draft give thickness and choice
the original object is not modified
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Topological_data_scripting. My macros on Gist.github here complete macros Wiki and forum.
mario52
Post by mario52 »
hi
can be useful Macro_FCWire_To_Volume
select the wires and create
mario
triplus
Post by triplus »
Good job @mario52.
P.S. If both functionality would be combined in the future:
viewtopic.php?f=8&t=17755#p139705
That would make a nice Part command.
mario52
Post by mario52 »
hi
with objects Draft ?
mario
triplus
Post by triplus »
That tool does work with solids and your with 2D geometry and it produces solids. Therefore indeed maybe 2 separate tools instead of one complex makes more sense.
efyx
Post by efyx »
17) Is it possible to add "Fits The Whole Content on a Screen" after closing sketch? Most cases before extrusion it is needed to do that anyway.
triplus
Post by triplus »
I use more general solution. That is create a macro first:
Gui.activeDocument().activeView().viewAxonometric()
Gui.SendMsgToActiveView("ViewFit")
After you can create toolbar command out of it:
http://www.freecadweb.org/wiki/index.ph ... e_ToolsBar
In FreeCAD 0.17 features like this are being explored and implemented and the trend is raising. Although i like most of them some try to enforce certain worfklow too much. And that isn't all that desirable from my point of view.
P.S. And as @mario52 took initiative and made macro based on your desires. It i guess would be appropriate to at least give him some feedback after you tested it.
efyx
Post by efyx »
triplus wrote:That is create a macro first:
Looks like this formula is the same as existing button "Fits the Whole Content on the Screen" or am I wrong. I thought would be good after closing sketch automaticly it would positioning it on a screen.
mario52 wrote:...
I have just while ago tested your macro. It is not 100% what I thought but look like it works well, and for sure will be usefull. Thanks. In my point of view if that would work with sketch would be perfect - I am not familiar with draft workbench but looks like editing/dimensioning is more problematic than in sketch. Also dynamic selection of what part of shape I would pick for extrusion will be perfect.
