Help on Revolve, please
I have 2 shapes I like to "Revolve" the faces to a curved solid joining them together to make a strut. From the instructions on the Part Workbench re "Revolve a Selected Shape" it should be possible to revolve a face to a solid, but nothing seems to happen. I always get the message, "Selected an object, first, even though I have tried selecting objects, faces and lines. Cannot make out what I am doing wrong.
Version: 0.16.6703 (Git)
Branch: releases/FreeCAD-0-16
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
- Strut.FCStd
- (12.7 KiB) Downloaded 40 times
Maavhamt
[/size]Re: Help on Revolve, please
First you need an independent face/edge/point to revolve. FreeCAD does not recognize a face from a solid as being an independent object. First I'll take it you're wanting something like this -
So what i did was to first use ShapeBuilder to create a face from the 4 edges of the end of Upright and then revolved the independent face with the values of Base X=0, Y=5, Z=141.5 with the Axis set as X and an Angle of -90*
Basicly the same thing for the bottom, except Base Z=-141.5 and Angle is 90*. After that, it's just a simple matter of Fusing the 5 parts if you are wanting them to all be one.
Mark
OS: Kubuntu 14.04.4 LTS
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.18-dev
Mark
Qt version: 4.8.6
Hello Maavhamt,
You can make it in ways that are easier and require fewer steps. Unless you really want this strut to be made of separate parts?
If you want a strut made of a single solid, This is not very efficient.Maavhamt wrote:I have 2 shapes I like to "Revolve" the faces to a curved solid joining them together to make a strut.
Hi Markquick61 wrote:So what i did was to first use ShapeBuilder to create a face from the 4 edges
In the usual FreeCAD manner there is often many ways to do something. I just thought I would add that another method to get that face could be to use a Draft_Facebinder or perhaps mount a Sketch to the surface and use external geometry tool.
But of course your method and the above all have their advantages and disadvantages.
I have no doubt Norm also has some good ideas!
Jim
I'm waiting for Maavhamt to reply before providing them. Maybe I'm mistaken on what Maavhamt wants to achieve, then they would be irrelevant.jmaustpc wrote:I have no doubt Norm also has some good ideas!
That is a good idea .....so I was right, again, as usual! You did have a good idea!NormandC wrote:I'm waiting for Maavhamt to reply before providing them. Maybe I'm mistaken on what Maavhamt wants to achieve, then they would be irrelevant.jmaustpc wrote:I have no doubt Norm also has some good ideas!
Hey Jim,jmaustpc wrote:Hi Markquick61 wrote:So what i did was to first use ShapeBuilder to create a face from the 4 edges
Jim
And yet another tool that should be in Part. A Part > Make Face, along with Part > Array, maybe, (or maybe not), broken down to a Part > Ortho Array and Part > Polar Array with the nice Task dialog like we have with the other Part tools - no fiddling about with the Combo view > Data tab on initial invocation of the tool.
Mark
Good idea Mark. And I personally find ShapeBuilder's greatest weakness is that it does not produce parametric objects. This is why I seldom use it.
While I find ShapeBuilder quite useful, I concur, it could be more, if only an code monkey,(and I mean that with the utmost affection), would write it that way. Sadly, I am not that code monkey, and most likely never will be.NormandC wrote:Good idea Mark. And I personally find ShapeBuilder's greatest weakness is that it does not produce parametric objects. This is why I seldom use it.
Mark
Guys,
Thanks for all the input! Sorry I haven't replied earlier, I have had a busy weekend (we are moving house soon). Yes, I do want the strut to be one part. We envisage it being made from a strip stainless steel bent to shape.
Maavhamt
Maavhamt
Maavhamt
[/size]
