Ticket #2652 transparent cylinder in foreground only shown as wireframe when mouse over a transparent box in the backgrd
tobycz
Postby tobycz » Tue Jul 26, 2016 2:46 am
First of all, thanks a lot for very good piece of open source software!
Now for my question.
I have an interesting effect when I mouse over a transparent box in the background with a transparent cylinder shown in the foreground.
The cylinder is only shown as wireframe during mouse over (please see also attached images and attached example.FCStd).
Is this the intended behaviour?
Thanks!
Toby
OS: Windows 7
Version: 0.16.6704 (Git)
Branch: releases/FreeCAD-0-16
Hash: 0c449d7e8f9b2b1fb93e3f8d1865e2f59d7ed253
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
example.FCStd
(3.72 KiB) Downloaded 62 times
Reason: Added ticket number to thread title
NormandC
Re: transparent cylinder in foreground only shown as wireframe when mouse over a transparent box in the background
Postby NormandC » Tue Jul 26, 2016 5:00 am
Hello Toby,
Looks like a display glitch, I have the same thing here. But if you rotate the view, zoom out or a combination of the two, at some point the cylinder displays normally. Then it's back to wireframe again...
OS: Ubuntu 14.04.4 LTS
Version: 0.16.6703 (Git)
Build type: None
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
Python version: 2.7.6
Qt version: 4.8.6
tobycz
Postby tobycz » Fri Jul 29, 2016 6:32 am
Thanks for quick reply!
I have two quick questions.
Is there any workaround for that?
Is a display glitch considered as an issue and should I submit it to a tracker?
Thanks!
ulrich1a
Postby ulrich1a » Fri Jul 29, 2016 8:45 am
tobycz wrote:Is there any workaround for that?
I have often "display glitches". In a lot of case it helps to click "fit on screen" and then zoom again to the required level.
tobycz wrote:Is a display glitch considered as an issue and should I submit it to a tracker?
I would say, it is an issue. So its worth to put it into the bug tracker. On the other side FreeCAD has so much need for improvement, that I would expect it takes a long time until someone feels a need to fix this. But if it is in the tracker, it will not be forgotten.
Ulrich
tobycz
Postby tobycz » Tue Aug 02, 2016 4:56 am
Thanks, Ulrich!
Unfortunately "fit on screen" doesn't really solve the problem.
As soon as one rotates the view, the problem occurs again but it also disappears when one continues to rotate.
I will submit it to the tracker.
Toby
NormandC
Postby NormandC » Tue Aug 02, 2016 5:07 am
Yes, that way it won't be forgotten. I suggest you add a link to this topic in the bug report, then paste a link to the report here.
A hint: just paste the bug report ID number here, and add "bug" tags (just click on the "bug" button on the "Post a reply" toolbar.
Example:
[bug]2637[/bug]
will show as issue #2637.
tobycz
Postby tobycz » Tue Aug 02, 2016 6:20 am
Submitted to FreeCAD tracker : issue #2652
Postby Kunda1 » Thu Jan 19, 2017 3:51 pm
soft bump
Postby Kunda1 » Wed Jun 06, 2018 1:45 am
Can still reproduce on
OS: "Manjaro Linux"
Version: 0.18.13905 (Git) AppImage
Build type: None
Hash: e80b5678ccfa59a5222b91bdc7e748a53a468468
Qt version: 4.8.6
OCC version: 7.2.0
freedman
Postby freedman » Wed Jun 06, 2018 2:14 am
If you notice the transparency of the box is set to 66 and the cylinder is 20, set it to zero and all is good. The program is probably doing what it should, stuff kind of disappears when these numbers aren't set to zero.
