Printing to scale
XXX
Printing to scale
Postby XXX » Sun Aug 07, 2016 10:04 pm
No problem printing an image, but I don't seem to be able to print to scale.
How dose one do that with the following. (Didn't see documentation).
OS: Windows 7
Version: 0.16.6700 (Git)
Branch: releases/FreeCAD-0-16
Hash: 7b925d11aa69ac405b423635adb1e2833f18a817
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Thanks
quick61
Re: Printing to scale
Postby quick61 » Mon Aug 08, 2016 12:41 am
XXX wrote:No problem printing an image, but I don't seem to be able to print to scale.
OS: Windows 7
Qt version: 4.8.6
Thanks
Place on Drawing Sheet as 1:1 scale, to size you intend to print out on and export as PDF and Print the PDF or if you printer will handle the size of Drawing sheet you use, print to that size, 100% scale from the Drawing workbench. I have done it both ways with good results. The key is to use the correct template/page size then you intend to print on.
Mark
jmaustpc
Postby jmaustpc » Mon Aug 08, 2016 1:32 am
Another key point is that most printer drivers will "scale image to fit page" by default, you must turn that off. Also sometimes you can get problems with printer margins, cutting off the edges of forcing the image to scale to fit within the printer margin rather than the page size. But these things are printer and printer software issues independent from FreeCAD or any other application.
