sgrogan wrote:easyw-fc wrote:tested Calculix cxx211-64bin.exe in FC 8434-64b and worked like a charm!
(and running much faster 62s vs 128s on my sample FC file)
Can you upload the binaries somewhere?
FreeCAD Window$ user compiling calculix
Amazing
I uploaded also the MultiThread release
CalculiX-bin-folder/win64
ccx2_11_MT-64.exe
there is also a batch file
ccx2_11_MT-64.bat
that can be invoked inside FC FEM and when launched SET environment variables to let ccx work in MT, and launch ccxMT for executing the FEM analysis
.... I considered all parameters to be passed to the batch file and then to CalculiX
Here a log of the ccx out showing the multicore calculation
0.0: Check dependencies...
51.3: Write completed.
0.0: CalculiX binary: C:/Calculix-211-64/ccx211_MT-64.bat
0.0: Run CalculiX...
0.0: Starting CalculiX...
0.0: CalculiX is running...
44.7: CalculiX stopped.
44.7: number of Processors 4
c:\users\userm\appdata\local\temp>SET OMP_NUM_THREADS=4
c:\users\userm\appdata\local\temp>SET CCX_NPROC_RESULTS=4
c:\users\userm\appdata\local\temp>\Calculix-211-64\ccx211_MT-64.exe -i Fusion001_Mesh
CalculiX Version 2.11, Copyright(C) 1998-2015 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on 16 Sep 2016 23:34:29
The numbers below are estimated upper bounds
number of:
nodes: 47104
elements: 40923
one-dimensional elements: 0
two-dimensional elements: 0
integration points per element: 15
degrees of freedom per node: 3
layers per element: 1
distributed facial loads: 6089
distributed volumetric loads: 0
concentrated loads: 1
single point constraints: 3
multiple point constraints: 1
terms in all multiple point constraints: 1
tie constraints: 0
dependent nodes tied by cyclic constraints: 0
dependent nodes in pre-tension constraints: 0
sets: 6
terms in all sets: 144726
materials: 2
constants per material and temperature: 2
temperature points per material: 1
plastic data points per material: 0
orientations: 0
amplitudes: 6
data points in all amplitudes: 6
print requests: 2
transformations: 0
property cards: 0
STEP 1
Static analysis was selected
Newton-Raphson iterative procedure is active
Decascading the MPC's
Determining the structure of the matrix:
number of equations
188413
number of nonzero lower triangular matrix elements
5500326
increment 1 attempt 1
increment size= 1.000000e+00
sum of previous increments=0.000000e+00
actual step time=1.000000e+00
actual total time=1.000000e+00
iteration 1
Using up to 4 cpu(s) for the stress calculation.
Using up to 4 cpu(s) for the heat flux calculation.
Using up to 4 cpu(s) for the symmetric stiffness/mass contributions.
Factoring the system of equations using the symmetric spooles solver
Using up to 4 cpu(s) for spooles.
average force= 0.000000
time avg. forc= 0.010000
largest residual force= 0.000000 in node 1 and dof 1
largest increment of disp= 0.000000e+00
largest correction to disp= 0.000000e+00
average flux= 0.011339
time avg. flux= 0.011339
largest residual flux= 0.048694 in node 20025 and dof 0
largest increment of temp= 1.629882e+00
largest correction to temp= 1.629882e+00 in node 1 and dof 0
no convergence
iteration 2
average force= 0.016701
time avg. forc= 0.016701
largest residual force= 7.520585 in node 15130 and dof 3
largest residual flux= 0.000000 in node 15103 and dof 0
largest correction to temp= 1.903474e-13 in node 8645 and dof 0
no convergence
iteration 3
average force= 0.000106
time avg. forc= 0.000106
largest residual force= 0.000000 in node 15108 and dof 3
largest increment of disp= 1.690264e-03
largest correction to disp= 1.690264e-03 in node 10203 and dof 3
largest residual flux= 0.000000 in node 21464 and dof 0
largest correction to temp= 1.408816e-14 in node 3656 and dof 0
convergence
the increment size exceeds the remainder of the step and is decreased to 0.000000e+00
Job finished
44.7: CalculiX done!
44.7: Loading result sets...
Please have a try and give feedback
Maurice
