[SOLVED] Snap icons missing - Bug?
Giulio Buccini
Postby Giulio Buccini » Sun Aug 28, 2016 3:31 pm
In the draft workbench the button icons of the "Draft Snap" toolbar are not displayed. :(
To reproduce:
1. start FreeCAD
2. switch to the Draft workbench
System info:
OS: Ubuntu 16.04.1 LTS
Version: 0.17.7744 (Git)
Build type: Unknown
Branch: occt7
Hash: fee4ade78217a581a6ea17011e39364e5ff7732f
Python version: 2.7.11+
OCC version: 7.0.0
Last edited by Giulio Buccini on Sun Aug 28, 2016 5:56 pm, edited 1 time in total.
NormandC
Re: Snap icons missing - Bug?
Postby NormandC » Sun Aug 28, 2016 3:57 pm
There is no such problem with the freecad-daily package from the Daily Builds PPA.
Giulio Buccini wrote:OS: Ubuntu 16.04.1 LTS
Build type: Unknown
Branch: occt7
Is there any specific reason why you compiled this occt7 branch? It is quite old, near 600 commits behind current master.
OS: Ubuntu 14.04.5 LTS
Version: 0.17.8317 (Git)
Build type: None
Hash: 18e519571af104abc0e09ab63ec8786143598df5
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Giulio Buccini
Postby Giulio Buccini » Sun Aug 28, 2016 4:10 pm
As suggested in the FreeCAD website, I've installed it by using the "Ubuntu Software Center".
It was listed as an available application for Ubuntu 16, I've just pushed the button "Install".... :?
NormandC
Postby NormandC » Sun Aug 28, 2016 4:16 pm
Is that a snap package?!? Because the Ubuntu 16.04 repository currently has the old 0.15.4671 version.
The snap package was a test made months ago, based on an unfinished, incomplete and buggy development version.
I recommend you add the Stable Releases PPA to your software sources and install the 0.16.6703 package.
Latest Stable Release from the "stable releases" PPA or "daily" PPA
Giulio Buccini
Postby Giulio Buccini » Sun Aug 28, 2016 4:41 pm
I'm installing the "daily" version. Should I install the stable version instead?
I would just draw some simple mechanics for my personal small projects ( so it would not funny to loose my work for bugs)... at the same time I would contribute in discovering bugs.
NormandC
Postby NormandC » Sun Aug 28, 2016 4:46 pm
The daily version brings huge changes to the PartDesign workbench. While these changes were necessary, they brought bugs, and many things may yet change. Most importantly, much of the available written or video tutorials become obsolete.
What I recommend is to use the stable version for your projects. You'll be able to benefit from a wide range of tutorials. If you want to contribute in reporting bugs (your help is welcomed in that regard :) ), you can also keep the daily package, they can now both be installed at the same time.
Giulio Buccini
Re: [SOLVED] Snap icons missing - Bug?
Postby Giulio Buccini » Sun Aug 28, 2016 5:58 pm
I've installed the stable release and the icons are now correctly displayed. :)
So, the version listed in the Ubuntu Software Center is decisively old. Uninstall it if you have yet installed.
My system info now:
Version: 0.16.6703 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
NormandC
Postby NormandC » Sun Aug 28, 2016 6:05 pm
Giulio Buccini wrote:So, the version listed in the Ubuntu Software Center is decisively old.
Actually, it is more recent (0.17.7744) than the stable version (0.16.6703). But it looks like there's a packaging problem. Also, it is old compared to the current development version available in the daily PPA. Right now, it contains the version 0.17.8317.
FYI: The first two digits after the zero define the version (0.16, 0.17), and the 4 last digits define the revision. The revision number is based on the commits in the master source code branch. A commit is a change in the source code, either to add a new feature or to fix a bug.
xf3qc
Postby xf3qc » Sat Mar 31, 2018 10:52 pm
Same issue.
