hi guys,
I am trying to export the drawing page into dxf file in the Drawing and Dimensioning module. But some error is coming..
How to rectify the error? And how to convert a drawing page into dxf file?
Thanks & Regards,
Satheesh
OS: Ubuntu 14.04.5 LTS
Version: 0.16.6703 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
How to export the drawing page into dxf file?
- dxf.png (215.5 KiB) Viewed 1290 times
Re: How to export the drawing page into dxf file?
Hello.
Tested with 0.16.6706 on Windows 7 64-bit.
Created NEW drawing (export most likely will not work with drawings created with older versions).
1.) Export drawing from Drawing Workbench
> Select page-object to be exported in tree view
> Choose "File > Export" from top menu, set file type to "Autodesk (*.dxf)"
> File succesfully exported and opened in LibreCAD
2.) Export from Drawing Dimensioning Module
> works ONLY on Ubuntu
> needs EXTRA Python library DXFWRITE to be installed
> has some limitations (see linked page)
3.) other possibility
> Export page-object as svg
> open in inkscape and save as dxf
Not tested yet, may have some limitations (svg is not dxf, right ?)
Roland
Roland
My GrabCAD FreeCAD-Projects
Native german speaker - so apologies for my english, no offense intended
Hello Satheesh,
Rather than posting the screen capture, all you had to do is to copy the error shown in red text in the report view.
Roland's second solution may solve the problem.
FYI the Drawing Dimensioning module is no longer being maintained. So bugs will not be corrected, unless a new developer steps in to take charge of the module.satheesh wrote:I am trying to export the drawing page into dxf file in the Drawing and Dimensioning module.
Thank you guys, after installing dxfwrite it is working fine.
