Hi!
Seems like OCC bug.
1. Skecther. Ellipse.
2. Part Offset2D
3. Part Extrude.
4. Part CheckGeometry -> lots of errors "BOPAlgo_InvalidCurveOnSurface"
Version: 0.17.8361 (Git)
Branch: DeepSOIC10
Hash: 4ac7673e543274bcae856872033a114c7b60481b
Python version: 2.7.8
OCC version: 7.0.0
Extrude Offset Ellipse is invalid geometry
Re: Extrude Offset Ellipse is invalid geometry
I wanted to reproduce this in occ draw and encountered this bug: https://tracker.dev.opencascade.org/view.php?id=27876 So sorry, I don't think there is a way to properly test this for occ problems and to possibly report it right now.
Even in Python it fails:
A new enum type for curves has been added with a recent occ version:
GeomAbs_CurveType.hxx
s=App.ActiveDocument.Offset2D.Shape
s.Edges
e=s.Edge1
e.Curve
EDIT:Traceback (most recent call last):
TypeError: undefined curve type
enum GeomAbs_CurveType
GeomAbs_Line,
GeomAbs_Circle,
GeomAbs_Ellipse,
GeomAbs_Hyperbola,
GeomAbs_Parabola,
GeomAbs_BezierCurve,
GeomAbs_BSplineCurve,
GeomAbs_OffsetCurve, // <<== that's new
GeomAbs_OtherCurve
This is quite old, but as OCC has finally fixed the bug I mentioned in the earlier post and updated the documentation. I was now able to report the bug mentioned by DeepSOIC: https://tracker.dev.opencascade.org/view.php?id=28982
Hello,
Using strictly the data of your "sketch", I applied constraints on the drawing (for a sketch entirely constrained). Then, the extrusion proceeds normally without any bug ...
(Sorry for my approximate English because I am French)
Here for you :
Greetings, Jean-Michel
OS : Windows 8.1 - 64bits
PC : ASUS N751 JK-T7118H – 17.3" IPS
µP : Intel Core i7-4710HQ - RAM : 16Go DDR3-1600
CG : NVIDIA Geforce GTX850 4Go dédiés
DD : 1To 7200t/mn - SSD : 128Go
FreeCAD :
64-bit Version : 0.16.6704 (Git)
Build type : Release
Branch : releases/FreeCAD-0-16
Hash : 0c449d7e8f9b2b1fb93e3f8d1865e2f59d7ed253
Python version : 2.7.8 - Qt version : 4.8.7 - Coin version : 4.0.0a - OCC version : 6.8.0.oce-0.17
Here for you :
FreeCAD :
