How to match herringbone gears?
Grue
Postby Grue » Tue Nov 15, 2016 1:13 pm
I made two herringbone gears with the same helix, but different number of teeth. Unfortunately, they don't match. How to calculate helix pitch properly to match two gears?
Version: 0.16.6703 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 2ce5c8d2e3020d05005ed71f710e09e9aa561f40
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
Life sucks, then you die.
ickby
Re: How to match herringbone gears?
Postby ickby » Tue Nov 15, 2016 1:33 pm
To get the same gradient in movement direction of the helix I think you must scale the radius and pitch in an equal manner. This means if you halfe your radius you also need to half your pitch etc.
A_3
Postby A_3 » Tue Nov 15, 2016 9:40 pm
Check your gear dimension calculation, maybe something is missing.
Mongrel_Shark
Postby Mongrel_Shark » Wed Nov 16, 2016 6:00 am
Shouldn't those gears be the same thickness?
mario52
Postby mario52 » Wed Nov 16, 2016 11:25 am
hi
see here tandwiel.info
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
looo
Postby looo » Wed Nov 16, 2016 11:59 am
I use this to compute the helix:
angle=height * tan(beta) * gear_radius
auxspine = makeHelix(height * 2 * pi / abs(angle), height, 10., 0, bool(angle < 0))
beta is the angle of the cutting rack rotation.
please help with my conda-packaging efforts: https://liberapay.com/looooo/
minimalistic blog: https://looooo.github.io/mini-blog/
Gentlemanrider
Postby Gentlemanrider » Thu Nov 17, 2016 3:03 pm
Just scale the helix pitch proportional to the teeth number ;)
