Scaling Down an imported SVG
comeinandburn
Postby comeinandburn » Tue Feb 07, 2017 12:56 pm
HI,
This may be an extremely silly question, but when I attempt to scale down an imported SVG it seems to be able to scale up but not down. Is there something I'm doing wrong?
I'm creating text in Inkscape then converting it to a path, importing into FreeCAD, and upgrading it to create faces. Problem is it's way too large.
Any help would be appreciated.
OS: Mac OS X
Version: 0.16.6706 (Git)
Branch: tag: 0.16.6706
Python version: 2.7.11
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
Willem
Re: Scaling Down an imported SVG
Postby Willem » Tue Feb 07, 2017 1:30 pm
Hi, when importing an SVG file made in Inkscape you have to realize that 1 px in Inkscape is imported as 1 mm in FreeCad. Scaling can easiest be done in Inkscape.
Another possibility is that in FreeCad you create clones of your faces or extrusions. Clones can be scaled to the size you want
shoogen
Postby shoogen » Tue Feb 07, 2017 2:52 pm
Willem wrote:when importing an SVG file made in Inkscape you have to realize that 1 px in Inkscape is imported as 1 mm in FreeCad.
I thought this was only the case for exporting. AFAIK the importer uses 90 dpi per default.
https://github.com/FreeCAD/FreeCAD/blob ... VG.py#L510
Chris_G
Postby Chris_G » Tue Feb 07, 2017 3:08 pm
One thing to note, is that Inkscape 0.92, released last month, now has a 96 dpi scale.
comeinandburn
Postby comeinandburn » Tue Feb 07, 2017 5:50 pm
Thanks Willem, that helps alot... this begs another question though. Is there a way to constrain the scale to all axis at the same time without adding values for each co-ordinate?
NormandC
Postby NormandC » Tue Feb 07, 2017 5:56 pm
Are you aware that Image Draft ShapeString allows you to create text directly in FreeCAD?
comeinandburn
Postby comeinandburn » Fri Feb 10, 2017 12:25 pm
Thanks NormadC :) that's helpful! I've got a lot to learn.. ha ha.
