Shoelast
- microelly2
Re: Shoelast
sculpter prototype - mouse interaction to add/subtract material on a surface
running on a helper mesh the interaction time is acceptable, the calcualtion of the nurbs takes more time and can be executed as last step for a high quality surface.
this is the first version on a planar surface.
- microelly2
Re: Shoelast
smoothing the mesh with taubinRe: Shoelast
Getting there. One step at a time.
P.S. I guess two steps this time!
- microelly2
Re: Shoelast
Here is the workflow from last scan to smoothed ribs.
there are two possibilities to smooth the scan:
a) smooth the whole mesh https://www.youtube.com/video_id=uS2zYlrolSs
b) smooth each segment individually https://youtu.be/0dgZKYTk-Ck
for our testdata taubin smooth is good enough.
- microelly2
Re: Shoelast
It displays a scaled difference between scanned point and smooth point.
from here it is easier to see the areas where the change improves the model and where we have to do some rework.
- microelly2
Re: Shoelast
read means add material
blue subtract material
Re: Shoelast
Looks like something appropriate for winter time.
- microelly2
Re: Shoelast
the simulation of global warming
from the polar bear to the hippopotamus
- microelly2
Re: Shoelast
Split the periodic Nurbs (blue) into 3 segments
The idea behind is to have a method from a closed surface to an open one. in the next step the individual segments can be recombined to the tip or the rear of the shoe.
(or to model a tongue or other overlapping details)
- microelly2
Re: Shoelast
To connect the top of the shoe with the middle part we use leastsq optimizing to place the pieces together when the do not fit exactly.
In the next step the borders must be merged.
