Tapered Pad not doing what I require
rayhall
Postby rayhall » Tue Feb 21, 2017 10:48 pm
I have tapered pads near a round hole. The result of applying the pad is wrong. As I am new to CAD design I cannot workout how to achieve what I require. Any help will be appreciated. I have attached the design file and this image shows the problem.
Ray.
OS: Windows 7
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
AudiV10ExhaustFlange.FCStd
(80.85 KiB) Downloaded 33 times
cox
Re: Tapered Pad not doing what I require
Postby cox » Tue Feb 21, 2017 10:57 pm
By changing the pocket parameter Midplain to true, and doubling the Length parameter. You efectivly pocket 5mm to each side of the sketch.
sgrogan
Postby sgrogan » Tue Feb 21, 2017 10:59 pm
Hello rayhall,
Nice Post! It's clear to see your problem. For Pocket001 and Pocket002 check "Symmetric to plane" and change Length to 10mm.
Fortunately the radii of your half slots are big enough to work.
AudiV10ExhaustFlange_rev.FCStd
(81.78 KiB) Downloaded 30 times
@cox was too fast :)
EDIT: cox changed the value in the parameter editor (data tab) I re-opened the Pocket dialog.
DeepSOIC
Postby DeepSOIC » Tue Feb 21, 2017 11:02 pm
Hi!
I was about to suggest you use 2 lengths mode of Pocket, but apparently it doesn't exist :oops:
What you can do is tick "Symmetric to plane" checkbox in pocket parameters, and double the pocket depth to compensate.
EDIT: OMG, a third post saying same thing :o
sgrogan
Postby sgrogan » Tue Feb 21, 2017 11:04 pm
DeepSOIC wrote: I was about to suggest you use 2 lengths mode of Pocket, but apparently it doesn't exist :oops:
My first impression as well. If the slot was narrower it would be a problem.
EDIT: Part Extrude has it. Smells like a feature request. I'll write it up.
EDIT2: issue #2915
rayhall
Postby rayhall » Wed Feb 22, 2017 12:46 am
I love this forum. The help is good and quick. Also getting to like FreeCad rather then pen and paper.
The "Symmetric to plane" recommendation worked well. Thank you.
Ray.
sgrogan
Postby sgrogan » Wed Feb 22, 2017 12:56 am
rayhall wrote:I love this forum.
Thanks!
If I could ask, how did your formulate your post? A screenshot, About FreeCAd info, and sample file makes it easy. Did you read the IMPORTANT, search the forum, wiki?
rayhall
Postby rayhall » Wed Feb 22, 2017 1:35 am
I am not sure what I have done wrong. I did include the FreeCad information. I used Snagit to capture the screen shot then Windows Paint to add the yellow circle. I then loaded the image on my server and put the link to it in the post. I did not search the forum for the answer first if that is what you are asking.
Ray.
NormandC
Postby NormandC » Wed Feb 22, 2017 2:47 am
Hi Ray,
You misunderstand sgrogan's question, he was noting that your question was well written and very clear and he was wondering how you knew to post such concise and helpful information. It is not as frequent as you think, we sometimes have to do a lot of back and forth before pinpointing a newcomer's issue.
rayhall
Postby rayhall » Wed Feb 22, 2017 3:23 am
Hello NormanC,
I ran my own forums for years doing technical support for the engine management I sold. I know just how frustrating this can be. I would get post with just "My engine will not start, what could be wrong"
Ray.
