Printing a scaled drawing to paper
I am trying to learn how to print my drawing on paper but having trouble following the tutorials. I want to select a group of objects and send them to my page drawing at a given scale. The only thing that I found that works is selecting each object one at a time and scaling it. I'm sure there is a better way since some of my drawings will have hundreds of items.
OS: Windows 8.1
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
OS: Windows 8.1
- Foundation.FCStd
- (588.21 KiB) Downloaded 72 times
Re: Printing a scaled drawing to paper
Arriving in FreeCAD 0.17 with TechDraw_NewMultitantle1961 wrote: I'm sure there is a better way since some of my drawings will have hundreds of items.
Renato
Edit
Here is a view of many objects from your file, Scale Type = Automatic
This can already be done right now in v0.16.670x.renatorivo wrote:Arriving in FreeCAD 0.17
What you need to know is that the Drawing workbench can only create views of a single object at a time. But this limitation can easily be worked around by creating a compound of your objects.
Select all the objects you want to put in a view (easy enough with box selection in the 3D view, Shift + B), then switch to the Part workbench and go to Part --> Make compound. Then you can create a view of the compound.
The compound is a new object that links all types of shapes together; the original shapes are hidden and nested under it in the Model tree.
Just one thing, in your file the elements under the Group will be removed from it. Groups and compounds don't work well together.
Think of the compound as a way to create an assembly that can be moved as a single unit. The compound is a new object, it will move to a new location, but not the original objects.
My modified file is too large to attach here, if you want to check it let me know and I'll upload it to my Dropbox account.
OS: Ubuntu 16.04.2 LTS
Version: 0.16.6707 (Git)
Build type: None
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
- FC_tantle1961_Foundation_Drawing_01.png (133.65 KiB) Viewed 8499 times
Thank you for the tip. How do I add dimensions to the drawing and is there a way to print at a specified scale like 1/4" per foot?
In two waystantle1961 wrote:How do I add dimensions to the drawing
- By adding Draft Dimensions to the 3D view and projecting them to the drawing page https://youtu.be/nxNT0KychcY
- A lot easier is to use the Drawing Dimensioning module add-on to add dimensions directly to the page. See Installing under "Installing additional content" for an easy way to install additional modules to FreeCAD.
In the Ortho views parameters, uncheck "Auto scale / position". The scale needs to be set in a decimal value. 1/4" = 1' - 0" translates to 0.02083.tantle1961 wrote:is there a way to print at a specified scale like 1/4" per foot?
This has been quite helpful - I'm almost there. I watched the video several times and got the drawing on the page and the dimensions added to a group. I must have done some wrong because now when I select the dimension group, the button to add the dimension is disabled (grayed out).
There's been some changes since I made that video.
You need to select the X-Y Dims group and the Ortho_0_0 view before clicking on the Draft Drawing tool. The dimensions will automatically adopt the view scale and placement.
But as I said, it is so much easier using the Drawing Dimensioning workbench, which didn't exist back when I made that video. You are doing yourself a disservice by not trying it out.
Thanks for the tip! That is so much easier.
I am loving this
For example, 1'-6" instead of 18"
tool, very easy to use. Is there a way to configure the tool to display in feet and inches?Drawing Dimensioning
Unfortunately I doubt it. I had a look and didn't find any way to, apart from manually changing the value, which kind of defeats the purpose of extracting dimensions from the model.
The original Drawing Dimensioning module author was South African I think. As far as I know only the USA & Canada, and maybe Great Britain use inches, the 7 billion other human beings on the planet use the metric system. We're in the very small minority here...
