Part Placement - changing values
chris s
Post by chris s »
I am having problems moving a part to a desired location. I have created a sketch, then a pad, then I want to change the location of the pad in, say the z direction. When I try to type in a new value it does not change the value in the highlighted window, but the part moves to a different view angle depending on what number I type. This seems really weird, and I dont know if I am doing something wrong or is it a bug?
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
r-frank
Re: Part Placement - changing values
Post by r-frank »
Hello Chris.
Welcome to FreeCAD and the forum.
chris s wrote:then I want to change the location of the pad
In Part Design, please apply placement ONLY TO THE FIRST SKETCH USED, NOT THE SHAPE.
In Part workbench you can apply placement to the shape.
Roland
My GrabCAD FreeCAD-Projects
chris s
Post by chris s »
OK so I now have the pad, selected, and I select part workbench, but still cannot change the z value.
Chris_G
Post by Chris_G »
Are you sure you're changing the "Position" values, not the "Axis" values ?
chris s
Post by chris s »
Yes, position, not axis. I just checked to make sure.
UR_
Post by UR_ »
Hello Chris s,
please ensure that keyboard focus dont change while inserting numbers into textbox.
If cursor stops blinking, focus is lost and futher keystrokes are taken for view shortcuts.
Numbers are view shortcuts:
menu standard views.png (62.73 KiB) Viewed 2690 times
If you click onto graphics screen while typing, keyboard focus gets lost (cursor stops blinking)
Hope it helps
chris s
Post by chris s »
Thank you, that explains what I didnt know about the numbers shortcuts. But I still cannot enter any values. Cursor does not blink, so I have no focus to start with. I have not clicked in object window; I just click on pad, then go directly to the placement x,y,z field, but there is no cursor.
How can I get the focus?
chris s wrote:OK so I now have the pad, selected, and I select part workbench, but still cannot change the z value.
You have to select the Sketch and not the Pad, as r-frank said before :roll: .
You can change the position of objects created in the Part Workbench. If they are created in Part Design Workbench you don't create new objects with each operation, but only new features of always the same object. Thus it can be moved only by moving the first sketch.
chris s
Post by chris s »
OK thanks to all for the help.
