I have a design that was made by importing an SVG drawing (path), making it a face, and then extruding that along the Z axis. It turns out that the SVG was based on a sketch that was made by overlaying a part on paper and tracing a line around it with a pen - so the sketch was offset around 1-2mm outside the perimeter of the original object.
As a result, I'd like to virtually shave off a couple of mm around the perimeter, or do a negative offset (inset?) of the outline of my object on the XY plane. Is this practically feasible? Do I have to go back and try to do this with the SVG, or the original sketch? I don't want to shrink the entire object, that would result in wrong measurements other places. I want holes/gaps to be bigger, but the outline to be smaller.
fcstd attached.
OS: Ubuntu 16.04.2 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
Inset object along XY
- sample.fcstd
- (11.25 KiB) Downloaded 28 times
Re: Inset object along XY
- You could use a fillet around the face. The inner edges are then offset by the fillet radius.
- Next you can Draft downgrade until you get the faces.
- Delete all fillet faces, and keep the inner face which is what you wanted.
- Last you can Part->Extrude the face again.
Or you can just hide the things you aren't going to use, but that makes for a bigger file size. The attached file uses the method explained by chisb, but I didn't delete anything. The blue outline is the original shape and grey is 2mm offset (the odd coloration of the top surface is the result of z-fighting):
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Build type: None
OS: Ubuntu 16.04.2 LTSWord size of OS: 32-bit
Build type: None
hi, a more simple method
Extrude SVGface with the extrude function in part design, this is what you already did, but change the taper angle to -10 or another angle that creates the inset you want
In draft workbench make a facebinder to the smaller top face
Extrude the facebinder
- sample-willem.fcstd
- (103.2 KiB) Downloaded 25 times
Thanks for the suggestions! I think chrisb's suggestion is the simplest since I know the distance I want to inset, with Willem's suggestion I need to do some (simple) calculation.
A drawback I think so far is that I'd like to script this, and doing the Draft -> Downgrade I get lots of faces. How will I know which face to keep? I guess I could traverse all App.ActiveDocument.Face* and sort by .Shape.Area, keeping the second largest.
Also, another shape I have just disappears when I try to create a fillet of 1mm or more. I can manage a fillet of a bit less than 1mm, but I think that's too little. None of the details are that small, as far as I can tell. Any ideas why it won't fillet?
- sample2.fcstd
- (18.05 KiB) Downloaded 25 times
Seems like insetting in inkscape may be easier. Editing the SVG in inkscape, I could simply choose Edit -> Preferences -> Behaviour -> Steps to define the inset distance, and then simply select the path and choose Path -> Inset. I use this "script" to convert to an object:
from FreeCAD import Base
import importSVG
import Part
def extrudeSVG(filename, thickness):
doc = App.ActiveDocument
# Import SVG
importSVG.insert(filename, doc.Name) # returns None
Gui.SendMsgToActiveView("ViewFit")
# Get latest object in document:
SVG = doc.Objects[-1]
# Gui.ActiveDocument.activeObject()
# Gui.ActiveDocument.path3400
# All objects: App.ActiveDocument.Objects[0] etc
# Create face, hide SVG
tmp = Part.Face(Part.Wire(Part.__sortEdges__(SVG.Shape.Edges)))
if tmp.isNull(): raise RuntimeError('Failed to create face')
doc.addObject('Part::Feature', 'SVGFace').Shape = tmp
del tmp
SVG.ViewObject.Visibility=False
# Extrude face
SVGFace = doc.Objects[-1]
SVGExtrude = doc.addObject("Part::Extrusion", "SVGExtrude")
SVGExtrude.Base = doc.SVGFace
SVGExtrude.Dir = (0, 0, thickness)
SVGExtrude.Solid = (True)
SVGExtrude.TaperAngle = (0)
doc.SVGFace.ViewObject.Visibility = False
doc.recompute()
# Demo use:
# extrudeSVG(u"/path/to/file/design.svg", 4)
- DeepSOIC
Last but not least, in 0.17 Part workbench got a 2D Offset tool.
I cannot tell for sure, but here seems something going wrong (please have in mind that filleting is performed by the OCC kernel, lying out of scope of the FreeCAD developers):kefir wrote:Any ideas why it won't fillet?
- Bildschirmfoto 2017-03-12 um 19.56.48.png (32.97 KiB) Viewed 2540 times
