Sketcher hides gridlines
Cyber3DK
Postby Cyber3DK » Sun Mar 12, 2017 9:38 pm
Specific complaint: Sketcher is not rotating the drawing to make a line horizontal.
The problem is repeatable and how-to-reproduce is given in the attachment Sketcher_hides_gridlines_ap7b.pdf.
Thanks for considering this issue.
(Apologies for not even showing the Before and After screenshots here. My knowledge and/or system does not allow that at this time.)
Regards.
Sketcher, Partial Grid Lines, Before.png (3.98 KiB) Viewed 997 times
Sketcher, Partial Grid Lines, After.png (1.93 KiB) Viewed 997 times
(37.91 KiB) Downloaded 22 times
Re: Sketcher hides gridlines
Postby NormandC » Mon Mar 13, 2017 12:25 am
That's an issue that's been there a long time, and there have been many topics about it. Basically, after the first item is added to the sketch, the grid will automatically re-size to it. The workaround is to create a large rectangle that is big enough for a "work area" in which the grid will be visible (but you need to close the sketch then re-open it to see the grid re-size). You only have to delete the rectangle once you don't need it anymore.
But FYI, as far as I know most commercial parametric CAD programs with a constraint-based sketcher don't provide a grid at all. It is only there for visual reference. For me the snap-to-grid option is a travesty because it creates the false impression that you sketch is fixed - it is not, only applying constraints will do that.
bejant
Postby bejant » Mon Mar 13, 2017 6:47 am
Cyber3DK wrote:Specific complaint: Sketcher is not rotating the drawing to make a line horizontal
:lol: Those blasted templates...
bejant
Postby bejant » Mon Mar 13, 2017 6:57 am
Humor somewhat aside, someone already submitted a ticket about that. See here:
issue #1271
Cyber3DK
Postby Cyber3DK » Mon Mar 13, 2017 11:55 pm
Thanks. Let's close this thread and wait for issue #1271 to be resolved.
sgrogan
Postby sgrogan » Tue Mar 14, 2017 12:04 am
If you put the issued in "bug" tags it will be linked.
[bug]1271[/bug]
issue #1271
Cyber3DK
Postby Cyber3DK » Tue Mar 14, 2017 12:08 am
Thanks.
Do I need to repeat my original message in the Forum?
sgrogan
Postby sgrogan » Tue Mar 14, 2017 12:15 am
Cyber3DK wrote:Do I need to repeat my original message in the Forum?
No, we all learn as we go. Thanks for taking notice.
