FEM Workbench: FreeCAD hangs after clicking on "Run Calculic" button
Hi All
My system information is as follows:
OS: Windows 7
Version: 0.16.6706 (Git)
Branch: releases/FreeCAD-0-16
Python version: 2.7.8
OCC version: 6.8.0.oce-0.17
I getting acquaint to FreeCAD using FreeCAD Manual. In the "Getting acquaint with FEM" module of the manual, when i press "Run Calculix" button following error shows up on report view:
File "C:\Program Files\FreeCAD 0.16\Mod\Fem\_TaskPanelFemSolverCalculix.py", line 148, in calculixFinished
fea.load_results()
File "C:\Program Files\FreeCAD 0.16\Mod\Fem\FemTools.py", line 470, in load_results
raise Exception('FEM: No results found at {}!'.format(frd_result_file))
Exception: FEM: No results found at c:\users\shivak~1\appdata\local\temp/Fusion_Mesh.frd!
Regards
OS: Windows 7
fea.load_results()
Regards
- CalculiX button error.jpg (120.61 KiB) Viewed 2573 times
Re: FEM Workbench: FreeCAD hangs after clicking on "Run Calculic" button
This could have various reasons ...
You use the stable version of FreeCAD ...
bernd
FEM has seen hundreds of updates and fixes and prechecks in version 0.17 Thus it is highly recommended to use the latest development version 0.17.xxxxx if you really would like to work with FEM in FreeCAD.shivaksingh wrote:Version: 0.16.6706 (Git)
bernd
Hey Bernd
Even i agree with what you said. But the latest official release for windows and OSX is 0.16.
So I'm not sure regarding upgrading. Though if you have been facing such a issue and it was solved by the way you said i'm up for it.
Regards
Regards
@shivaksingh, The official releases are just snapshots taken in a quiet period of development (I'm open to correction ). Don't be afraid of using the most up-to-date development version, especially for FEM workbench.
There where hundreds of fixes and improvements fir FEM in 0.17.shivaksingh wrote:So I'm not sure regarding upgrading. Though if you have been facing such a issue and it was solved by the way you said i'm up for it.
Actually noone from the regular FEM users uses FreeCAD FEM with 0.16 release. As said before for FEM the use of latest 0.17 dev version is highly recomended!
I do not even have 0.16 installed.
But this only applys to FEM.
You can simply install development version from https://github.com/FreeCAD/FreeCAD/releases where is file like this
FreeCAD_0.1710887_x64_dev_win.7z
which you only unpack in your computer and launch \bin\FreeCAD.exe
It does not affect your 0.16 installation.
If you will use 0.17, contrary to the Manual (for 0.16 version) it is faster to create mesh after applying constraints. Use GMSH for meshing (icon https://www.freecadweb.org/wiki/File:FE ... mShape.png )
Thanks fandaLand bernd.
SOLVED
Regards
SOLVED
Regards
How am I supposed to work on the files created in FreeCAD 0.16 in FreeCAD 0.17?
What do you mean by this? Do you have probles in loading files from 0.16 in 0.17 ?shivaksingh wrote:How am I supposed to work on the files created in FreeCAD 0.16 in FreeCAD 0.17?
When I'm trying to run a file made using 0.16 version. Its asking to convert the file to be 0.17 compatible. When i clicked yes it changed my part.
I had designed H shaped geometry and was left with L shaped one.
Though thanks for your help. I redid it and 0.17 is amazing.
Regards
Regards
