3D dimensions in TechDraw
I want to make some 3D dimensions in the TechDraw module in an isometric view, the problem is that the dimensions lines are perpendicular to the projected line, and I want them in the direction of the axis.
Is this possible?
Is this possible?
- beam.png (19.59 KiB) Viewed 3791 times
- wandererfan
Re: 3D dimensions in TechDraw
No. Is this a common convention?Msegade wrote:Is this possible?
Yes.
Following image quickly made in the drawing module of a proprietary CAD program.
- Dimensioned_Iso_View.jpg (43.75 KiB) Viewed 3750 times
The text stays aligned like in techdraw... It would be just a matter of skewing the extension lines actually...NormandC wrote:Following image quickly made in the drawing module of a proprietary CAD program.
Look at ISO 5456-3... I think Normand is right.wandererfan wrote:No. Is this a common convention?Msegade wrote:Is this possible?
Sorry for non english links:
https://books.google.it/books?id=r3irIp ... -3&f=false
https://books.google.it/books?id=Nd0yK- ... -3&f=false
http://joho.p.free.fr/EC/COURS%20DOC/PE ... RIQUES.pdf
Marco_T
On that third link, I can translate the relevant French text:
To amend what I succinctly replied at the end of my lunch break: I don't think dimensioning axonometric views is considered an "official" convention in either of the existing norms (ISO, ANSI...), but it is commonly used nonetheless. And yes, the dim extension lines should be parallel to the XYZ axes.Dimensioning should be avoided in axonometric views. If it is necessary, the same rules as those used for orthogographic views should be employed.
So now in 0.19 I assume this has been implemented, since in the wiki it says it was introduced in 0.18:
https://wiki.freecadweb.org/Basic_TechDraw_Tutorial:
Im using 0.19 and I still see 3D dimensions perpendicular to the edge. I have gone through the Preferences trying to find a setting to set the behavior but can't. How does one enable it?This drawing was produced in v0.18. It shows dimensions in the proper format for an isometric view. In v0.17 the extension lines will be perpendicular to the edge rather than aligned with the axes.
Hi
Probably should start new post as this is an old post but
Do see what you are asking and do not find settings but have attached a file that I opened in 0.18 0.19 0.20 and it shows what you want in 0.18.
File is just quick, did not link the dimensions. Maybe try your file in 0.18
OS: Ubuntu 20.04.2 LTS (MATE/mate)
Version: 0.20.24789 (Git) AppImage
Hash: 31b0f25b6df1d1707fdf74135093831eec4f0281
Python version: 3.9.2
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
Version: 0.18.16146 (Git) AppImage
Branch: (HEAD detached at 0.18.4)
Python version: 3.6.7
Qt version: 5.6.2
Qt version: 5.12.9
Coin version: 4.0.0
OCC version: 7.5.1
Qt version: 5.6.2
- td.jpg (111.87 KiB) Viewed 2071 times
- 18.FCStd
- (9.02 KiB) Downloaded 26 times
Maybe it is a regression bug (I can open a bug report), or was this planned?
- thomas-neemann
because techdraw is slow, i dimension in 3d, so the problem does not arise. is that a solution for you too?
