How to create a handrail scroll/volute shape based on fibbonacci?
crobar
Postby crobar » Wed Apr 26, 2017 2:39 pm
I would like to create a scroll for a victorian style handrail, something like the picture below (don't know how to change the image size here?):
Victorian handrail scroll
More detailed description can be found at http://www.thisiscarpentry.com/2009/07/ ... -a-volute/
As a starter for 10 I have worked up a script which can create a fibbonacci (golden ratio) spiral:
from math import sin, cos, pi, sqrt
import Part
import Draft
from FreeCAD import Vector
def fibonacci_spiral_connected ( n=101 ):
  FIBONACCI_SPIRAL_CONNECTED draws connected points on a Fibonacci spiral.
  Licensing:
     This code is distributed under the GNU LGPL license.
   Modified:
     07 April 2011
   Author:
     John Burkardt
  Parameters:
     Input, integer N, the number of points to plot.
     Default is 101.
#  PHI is the golden ratio, the limit of the ratio of
#  successive Fibonacci numbers:
#    PHI = limit ( N->oo ) F(N+1)/F(N)
  phi = ( 1.0 + sqrt ( 5.0 ) ) / 2.0
#  Allocate storage for the point data.
#  x = zeros ( n, 1 )
#  y = zeros ( n, 1 )
#  Set the angle and radius of the first point.
  a = 0.0;
  r = 0.0;
#  Set the increments.
  da = 2.0 * pi * ( phi - 1.0 ) / phi;
  dr = 1.0;
#  Create a spiral in which the radius R and angle A both
#  increase by a constant increment,
  x = []
  y = []
  for i in range (1,n+1):
    x.append (r * cos ( a ));
    y.append (r * sin ( a ));
    a = (a + da) % (2 * pi);
    r = r + dr;
#  SCALE controls how many steps we take between the actual points.
#  A value of 5 is enough to see the basic spiral that connects the points.
#  A vale of 10 would make a smoother spiral.
  scale = 20.0;
#  Allocate storage for the intermediate data.
  n2 = scale * ( n - 1 ) + 1;
  #x2 = zeros ( n2, 1 );
  #y2 = zeros ( n2, 1 );
  a = 0.0;
  r = 0.0;
  dr = 1.0;
  da = da / scale;
  dr = dr / scale;
  #x2 = []
  #y2 = []
  pnts = []
  for i in range (1,int(n2)+1):
    pnts.append (Vector (r * cos ( a ), r * sin ( a ), 0))
    #x2.append (r * cos ( a ));
    #y2.append (r * sin ( a ));
    a = ( a + da ) % ( 2 * pi );
    r = r + dr;
#  Display the points,
#  and use the intermediate points to draw lines that display the spiral.
  return pnts
pnts2 = fibonacci_spiral_connected  (10)
goldenspiral = Part.makePolygon (pnts2)
Part.show (goldenspiral)
But I'm not sure what to do from here. Probably a sweep or loft?
crobar
Re: How to create a handrail scroll/volute shape based on fibbonacci?
Postby crobar » Wed Apr 26, 2017 9:21 pm
Made some progress with the attached script, but not sure where to go from here:
import math
import Part
import Draft
  Licensing:
   Modified:
     07 April 2011
   Author:
     John Burkardt
  Parameters:
     Default is 101.
  phi = ( 1.0 + math.sqrt ( 5.0 ) ) / 2.0
  a = 0.0;
  r = 0.0;
  da = 2.0 * math.pi * ( phi - 1.0 ) / phi;
  dr = 1.0;
#  x = []
#  y = []
#  for i in range (1,n+1):
#    x.append (r * cos ( a ));
#    y.append (r * sin ( a ));
#    a = (a + da) % (2 * pi);
#    r = r + dr;
  scale = 20.0;
  a = 0.0;
  r = 0.0;
  dr = 1.0;
  da = da / scale;
  dr = dr / scale;
  #x2 = []
  #y2 = []
  pnts = []
    pnts.append (Vector (r * math.cos ( a ), r * math.sin ( a ), 0))
    a = ( a + da ) % ( 2 * math.pi );
    r = r + dr;
  return pnts
#def makeWire (pnts):
#    ind = 0
#    edgelist = []
#    for p in pnts:
#        if ind > 0:
#            edgelist.append (Part.makeLine (pnts[ind-1], pnts[ind]))
#        nd = ind + 1
#    return Part.Wire (edgelist)
#n = 4 #eval(input())
#phi = (1+5**.5)/2
#w = int(phi**(4*(n//4)))
#k = pi/180
#pnts = [Vector (phi**(j/90)*cos(j*k)+w/2, phi**(j/90)*sin(j*k)+w/2, 0) for j in range(n*90)]
pnts2 = fibonacci_spiral_connected  (5)
#goldenspiral = Part.makePolygon (pnts2)
#gs2 = Part.Wire (goldenspiral.Edges)
Draft.makeBSpline (pnts2)
#Part.show (goldenspiral)
#Part.show (gs2)
# curved profile
w = 2.0
profile_pnts = [ Vector (0, -w/2, 0),
                 Vector (0, w/2, 0),
curveangle = 45.0
curvepnts = [ profile_pnts[0],
              Vector (0, -w*math.cos(math.radians(curveangle))+profile_pnts[0].y, w*math.sin(math.radians(curveangle))),
              Vector (0, w*math.cos(math.radians(curveangle))+profile_pnts[1].y, w*math.sin(math.radians(curveangle))),
              profile_pnts[1],
profcurve = Part.BezierCurve()
profcurve.setPoles (curvepnts)
profline = Part.makeLine ((profile_pnts[1].x, profile_pnts[1].y, profile_pnts[1].z) ,
                        (profile_pnts[0].x, profile_pnts[0].y, profile_pnts[0].z) )
profile = Part.Face (Part.Wire ([profcurve.toShape(), profline]))
#profile.rotate ( profile.CenterOfMass,
#                 Vector (0,0,1),
#                 90.0 )
Part.show (profile)
if I sweep the profile along the curve I get this:
renatorivo
Postby renatorivo » Wed Apr 26, 2017 9:36 pm
Fibonacci spiral from Sketch and Sweep
fibonacci sweep.FCStd
(41.41 KiB) Downloaded 27 times
Renato
hammax
Postby hammax » Thu Apr 27, 2017 6:24 am
...Fibonacci-Spiral placing the sweep-profiles with one side on the sweepingspiral.
It's mor like the snailshell. Only Problem is, there are the little curls at the inside of the shell,
because the fibonacci-spiral is merely an approach to the real logarithmic spiral.
renatorivo
Postby renatorivo » Thu Apr 27, 2017 7:58 am
If I'm not mistaken, to have a flat side, it looks like this works best
hammax
Postby hammax » Thu Apr 27, 2017 9:27 am
...you can also do it with a conical Helix...
microelly2
Postby microelly2 » Thu Apr 27, 2017 10:31 am
I would calculate more ribs and interpolate it all as a bspline surface
this is not the fibonacci curve but with the modification of the trafo and scaler pts -> pts1 ist should work too.
import Draft
import numpy as np
anz=12
r=50
pts=[FreeCAD.Vector(r*np.cos(2*np.pi/anz*i),r*np.sin(2*np.pi/anz*i),0) for i in range(anz)]
#Draft.makeBSpline(pts)
pps=[]
for k in range(40):
	pts1=[FreeCAD.Vector((-200+ p.x)*0.5**(k*1.0/anz),p.y*0.5**(k*1.0/anz),0) for p in pts]
	ps=[ FreeCAD.Placement(f,FreeCAD.Rotation()) for f in pts1]
	trafo=FreeCAD.Placement(FreeCAD.Vector(100,0,0),FreeCAD.Rotation(FreeCAD.Vector(0,1,0),360.0/anz*k))
	pts2=[trafo.multiply(p).Base for p in ps]
	pts2 += [pts2[0]]
	Draft.makeBSpline(pts2)
	pps += [pts2]
bs=Part.BSplineSurface()
bs.interpolate(pps)
Part.show(bs.toShape())
crobar
Postby crobar » Thu Apr 27, 2017 3:29 pm
Thanks for the suggestions so far, the problem is that none of these crete the kind of shape needed, because the sweep actually needs to self-intersect and keep the profile shape. The closest I've come is the following script which makes it in parts and tries to fuse them at the end, but the fuse fails, or at least the resulting geometry has errors. I think this is an OCC limitation or bug.
import math
import Part
import Draft
import sys
sys.stdout.flush()
  Licensing:
   Modified:
     07 April 2011
   Author:
     John Burkardt
  Parameters:
     Default is 101.
  #a = 0.0;
  #r = 0.0;
  #da = 2.0 * math.pi * ( phi - 1.0 ) / phi;
  #dr = 1.0;
#  x = []
#  y = []
#    r = r + dr;
  scale = 50.0;
  a = 0.0;
  r = 0.0;
  dr = 1.0;
  da = da / scale;
  dr = dr / scale;
  #x2 = []
  #y2 = []
  pnts = []
    r = r + dr;
  return pnts
def FibIter():
  a,b = 0,1
  yield a
  yield b
  while True:
    a, b = b, a + b
    yield b
#    ind = 0
#    edgelist = []
#    for p in pnts:
#        if ind > 0:
#        nd = ind + 1
#phi = (1+5**.5)/2
#profwidth = int(phi**(4*(n//4)))
#k = pi/180
#pnts = [Vector (phi**(j/90)*cos(j*k)+profwidth/2, phi**(j/90)*sin(j*k)+profwidth/2, 0) for j in range(n*90)]
nquarterturns = 5
pnts2 = fibonacci_spiral_connected  (nquarterturns)
sweeppath = Draft.makeBSpline (pnts2)
#Part.show (gs2)
# curved profile
profwidth = 2.0
profile_pnts = [ Vector (0, -profwidth/2, 0),
                 Vector (0, profwidth/2, 0),
curveangle = 45.0
              Vector (0, -profwidth*math.cos(math.radians(curveangle))+profile_pnts[0].y, profwidth*math.sin(math.radians(curveangle))),
              Vector (0, profwidth*math.cos(math.radians(curveangle))+profile_pnts[1].y, profwidth*math.sin(math.radians(curveangle))),
              profile_pnts[1],
#                 Vector (0,0,1),
#                 90.0 )
Part.show (profile)
nsections = 5*nquarterturns
pntspersection = len (pnts2) / nsections
fib = FibIter ()
startind = None
fullsectioniterstart = 6
sectioncount = 0
finalpart = Part.makeCylinder (2.5, 0.6)
finalpart.translate(Vector (0,0,-0.55))
finalpart = finalpart.fuse (Part.makeCylinder (1.2, 0.65))
Part.show (finalpart)
while True:
#for n in range (nsections):
    done = False
    if startind is None:
        startind = fib.next ()
    thisprofile = profile.copy()
    shiftpnt = thisprofile.CenterOfMass
    if sectioncount < fullsectioniterstart:
        # cut the profile in half
        cutbox = Part.makeBox (profwidth, profwidth, 2.0*profwidth)
        cutbox.translate (Vector (-profwidth/2.0, 0, -profwidth/2.0))
        #Part.show (cutbox)
        #Part.show (thisprofile)
        thisprofile = thisprofile.cut (cutbox).Faces[0]
        #break
    endind = startind + 3*fib.next ()
    print ('starting section from points {} to {} of {}'.format (startind, endind, len(pnts2)))
    if endind > len(pnts2):
        #sweeppath = Draft.makeBSpline (pnts2[startpnt : ])
        sweeppath = Draft.makeBSpline (pnts2[(startind-2) : ])
        done = True
    else:
        if startind == 0:
            sweeppath = Draft.makeBSpline (pnts2[0 : endind])
        else:
        #sweeppath = Draft.makeBSpline (pnts2[n*pntspersection : (n+1)*pntspersection+1])
            sweeppath = Draft.makeBSpline (pnts2[(startind-2) : endind])
    pathtangent = sweeppath.Shape.tangentAt(0)
    #startpnt = pnts2[n*pntspersection]
    #startpnt = pnts2[(startind-3)]
    startpnt = Vector (sweeppath.Shape.Vertexes[0].X,
                       sweeppath.Shape.Vertexes[0].Y,
                       sweeppath.Shape.Vertexes[0].Z )
    # get rotation axis. We want to rotate the profile around the
    # vector orthogonal to it's face normal and the sweep path
    # tangent at the start of this sweep section
    rotAxis = profile.normalAt(0,0).cross(pathtangent.normalize())
    # get rotation angle, angle between the bannister vector
    # and the face normal vector
    cosA = profile.normalAt(0,0).dot(pathtangent.normalize())
    thisprofile.rotate ( shiftpnt,
                         rotAxis,
                         math.degrees (math.acos (cosA)) )
    # now shift the profile so that its centre aligns with the
    # start of the sweep path
    thisprofile.translate(startpnt - shiftpnt)
    # We use the Part.BRepOffsetAPI.MakePipeShell so we can
    # use the binormal mode which ensured
    ps = Part.BRepOffsetAPI.MakePipeShell(Part.Wire (sweeppath.Shape))
    # set the binormal vector to point in the Z axis
    ps.setBiNormalMode( Vector (0,0,1))
    #for pro in Profiles:
    #    ps.add( pro, False, False) # add(shape, contact, rotate_ortho )
    # supply the wire bounding the profile face
    ps.add (thisprofile.Wire)
    # make the sweep
    if ps.isReady():
        ps.build()
        x = ps.makeSolid() # optional
        Part.show(ps.shape().Solids[0])
    if finalpart is None:
        finalpart = ps.shape().Solids[0]
    else:
        finalpart = finalpart.fuse (ps.shape().Solids[0])
        #break
    #Part.show (finalpart)
    if done:
        break
#    else:
#        endind = startind + 3
    # the next start point should be the end point of this section
    startind = endind
    sectioncount = sectioncount + 1
I've can't attache the resulting project file as it's too large, but here's a screenshot:
microelly2
Postby microelly2 » Thu Apr 27, 2017 3:43 pm
The self intersecting sweep is a problem and I think there is no way to solve this problem using the sweep.
My example can configured that you create only segments of the surface and then connect them with some helper faces.
It's a lot of work, but if you have 4 edges you can create with part tools a filling face.
Postby chrisb » Thu Apr 27, 2017 5:06 pm
crobar wrote:Made some progress with the attached script, but not sure where to go from here:
There is a german post which might give you an idea how to use Sketcher for kind of "3D-Sketches": https://forum.freecadweb.org/viewtopic. ... 45#p165745. The videos mentioned there show what he has done.
You can start with a helper pad on the end of your spiral.
