Trouble with fuse, freecad crash on step export
crobar
Post by crobar »
Im having trouble with boolean union on some shapes. I have managed o boil the problem dow to two solids, see the attached file. Running checkgeometry on these shapes says they have no problems. When I fuse then, the resulting shape also has no errors according to checkgeometry, however, it does not render correctly, and if I export to step FreeCAD crashes, with the following error in the terminal:
*** Abort *** an exception was raised, but no catch was found.
	... The exception is:SIGSEGV 'segmentation violation' detected. Address 28
would be nice to know if this works in dev version with newer OCC
OS: Linux Mint 17.3 Rosa
Version: 0.16.6710 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: f8eca0f9311f07c125dd6742a607724c1fa0b77c
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
fuse_fail.fcstd
(10.21 KiB) Downloaded 50 times
NormandC
Re: Trouble with fuse, freecad crash on step export
Post by NormandC »
It does work in 0.17-dev with OCC 7.1.0.
OS: Ubuntu 16.04.2 LTS
Version: 0.17.10980 (Git)
Build type: None
Hash: d02a34c03b0c14342151a4343250b571a603ece9
Python version: 2.7.12
OCC version: 7.1.0
crobar wrote:would be nice to know if this works in dev version with newer OCC
You can install it from the daily builds PPA, the name of the package is freecad-daily, we changed it last year so both 0.16 and 0.17 could be installed. Prior to it, it was one or the other.
NormandC
Post by NormandC »
I spoke too soon. The union succeeds, the object appears OK in the 3D view, but check geometry reports it as invalid with a "tolerance value invalid" error. This may be fine, or cause problems later on...
Here's an alternative: cut one of the shapes' end so it perfectly matches the other. Then the fusion succeeds in 0.16.
What I did:
  1. Map a sketch on the bottom face of Shape008
  2. Sketch a closed profile; use the external geometry tool to pick two vertices of the face and apply point on object constraints between them and the profile
  3. Close the sketch, then go to Part Design --> Detach Sketch
  4. At the prompt "do you want to detach sketch", click Yes
  5. Cancel the Sketch orientation dialog (the sketch will be detached, but will keep its placement)
  6. Pad the sketch
  7. Apply a Part Cut with the Pad on the Shape007
  8. Fuse the Cut with Shape008.
Build type: None
crobar_fuse_working_normandc1.fcstd
(53.95 KiB) Downloaded 40 times
