Sluggish Spreadsheet on Complex Model?
Hi, I am trying to explore the Spreadsheet on my model.
I find it perform very slow. I try input in a cell, it is 1 or 2 s pause, each keystroke response is slow, enter follow by another few second pause.
Then I realize if i open a new empty file, it works without problem. I guess Spreadsheet is trying to reference objects in the models so it become very slow when the model is complicated and file is large? I have a mult-storey multi-flat building which is now about 12mB.
Any suggestion?
BTW, any more information available for Functions in Spreadsheet (& Arch Schedule) in addition to those I could find below?
https://www.freecadweb.org/wiki/Spreadsheet_Workbench
https://www.freecadweb.org/wiki/Manual: ... readsheets
Thanks!
OS: Linux
Version: 0.17.10989 (Git)
Build type: Unknown
Hash: 1a9c878b609aded0d04b725b1229f70dd045bb0e
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
Any suggestion?
Thanks!
OS: Linux
Build type: Unknown
Coin version: 3.1.3
Re: Sluggish Spreadsheet on Complex Model?
Yes it is also quite slow on my end. That's why I haven't done a tutorial on it yet.
Can you try with more updated version of FC? (current is r12870)
FreeCAD-0.17.git201712101906.glibc-x86_64.AppImage
FreeCAD-0.17.git201712210014.glibc-x86_64.AppImage
Still same performance... will see if I can single this out later if I have a moment.
Try right clicking on the document item in the tree view. There will be some options like an options to Skip recomputes or to Mark (the document) to recompute. When the Skip recomputes option will be enabled try to change the value in Spreadsheet cell after. To see if such approach will allow you to enter the value in one step.
Some further information to update, tested again on - FreeCAD-0.17.git201712101906.glibc-x86_64.AppImagetriplus wrote: ↑Thu Dec 28, 2017 2:23 pm Try right clicking on the document item in the tree view. There will be some options like an options to Skip recomputes or to Mark (the document) to recompute. When the Skip recomputes option will be enabled try to change the value in Spreadsheet cell after. To see if such approach will allow you to enter the value in one step.
- Still pause after input (i.e. input [enter] )something in a cell
- BUT, each keystrokes (e.g. =Sketch.Constraints.Constraint18) seems normal
- That's just pause after entering [enter]
- & Yes, Skip Recompute helps
It's probably this: https://freecadweb.org/tracker/view.php?id=2467paullee wrote: ↑Fri May 05, 2017 12:04 am Hi, I am trying to explore the Spreadsheet on my model.
Any suggestion?
Eivind
Thanks, sound very much like this one!eivindkvedalen wrote: ↑Fri Dec 29, 2017 3:53 pmIt's probably this: https://freecadweb.org/tracker/view.php?id=2467paullee wrote: ↑Fri May 05, 2017 12:04 am Hi, I am trying to explore the Spreadsheet on my model.
Any suggestion?
Eivind
See my post just above, on FreeCAD-0.17.git201712101906.glibc-x86_64.AppImage, it seem inputting is normal now - just after inputting [ after inputting [enter] ], there is still seconds of pause.
- Jose Hidalgo
Hi. I wanted to report that I'm using 0.19, and the spreadsheet is slow as hell. Any change (ANY, including typing a value in an empty cell) hangs my computer for more than 30 seconds.
My current model is 3.5 MB and not very complex : 30-40 bodies and a lot of holes.
Yes, I have an old PC (Core i3 530), but even so, this shouldn't be happening. Not to this extent.
The spreadsheet used to be reactive, but it became sluggish with the progressive growth of my model.
My model and FreeCAD are reactive as a whole, it's just the spreadsheet that isn't.
I can't believe that nothing can be done to optimize this any further.
@realthunder posted here that "there is no noticeable delay for completion with 1000+ objects". He most certainly doesn't have an old PC like me. The problem is still very real, unfortunately.
Merci à toutes les personnes qui m'ont aidé et m'aident encore à débuter et à m'améliorer sur FreeCAD
