If I create a project with multiple pages that share the same template, everything works fine the first time I create the pages.
If I save the project, close freecad, reopen the file and check templates of the pages, only one page has the right template, the others have template that don't exist.
For example, if template is A3_Landscape.svg, only one page has A3_Landscape.svg as template, the others have A3_Landscape1.svg, A3_Landscape2.svg etc.
If I change something in the drawing, I have a sign of error on the pages with non existing templates and, consequently, drawing doesn't update.
[SOLVED] Error reopening project with multiple pages with the same template
- multipages.fcstd
- (71.35 KiB) Downloaded 29 times
Re: Error reopening project with multiple pages with the same template
You are probably using FreeCAD 0.16 and you should have added your FreeCAD info here, as it says in the hard to miss link with the red background above.
You need a separate template for each drawing. You can simply copy them or if you are on a modern system like Ubuntu you can use symbolic links.
OP opened ticket issue #3037
OS: "Arch Linux"
Version: 0.16.Unknown
Python version: 2.7.13
Coin version: 3.1.3
OCC version: 6.9.1
I think it is not worth putting any effort into this: There is an easy workaround which has to be done a single time. In 0.17 there will be TechDraw Workbench replacing Drawing.
This is a known issue (FreeCAD 0.16). Unfortunately it was resolved only after FreeCAD 0.16 was released. Therefore when using FreeCAD 0.17 Drawing workbench to add drawing pages/templates and after reopening the document mentioned issue shouldn't be detected anymore (that is when using FreeCAD 0.17). In the new issue report it is said TechDraw has the same issue. AFAIK it does not have such issue and therefore more elaboration on this is needed.
The bug report lists only the details of the 0.16 version. I checked with the current 0.17 (see below). No problem there. I added a comment to the issue.
Perhaps mickele has seen the path of the templates in the TechDraw page. They point in fact to two different files, but those are pointers to some files below the systems tmp-directory. I don't know what happens when I move the FreeCAD file to another system.
OS: Ubuntu 14.04.5 LTS
Version: 0.17.11104 (Git)
Build type: None
Hash: 1b2b964c35bd0f989f1f833a372c48e08cec0194
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 7.1.0
Build type: None
Qt version: 4.8.6
OCC version: 7.1.0
No problem here either with drawing and templates.
A search for "template" in the bugtracker found 7 matches of which the 3rd issue #2184 is the same as issue #3073 discussed here.
OS: Mac OS X
Version: 0.17.10993 (Git)
Branch: (detached from bf5f348)
Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291
Qt version: 5.6.2
OCC version: 7.1.0
And I checked the TechDraw as well: no problem opening the file on another system.
OS: Mac OS X
Qt version: 5.6.2
OCC version: 7.1.0
- wandererfan
That is correct. TechDraw includes the template from the originating machine into the FCSTD file, then uses the included file on subsequent opens.chrisb wrote:And I checked the TechDraw as well: no problem opening the file on another system.
Re: [SOLVED] Error reopening project with multiple pages with the same template
Ok, I had checked an old git-version. Effectively with recent versions the issue is solved.
