I am using version 10990 available on git.
From Drawing module, when printing a view of an object, printed lines are too large. Changing parameter Line Width in the view gets no result.
Any idea about possible causes?
OS: Windows 7
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.17.10990 (Git)
Hash: 378a1e4f5804babb7704c237512093a11afde757
Python version: 2.7.8
OCC version: 7.0.0
Drawing module - Line thickness
- line-thickness-screenshot.jpg (163.9 KiB) Viewed 1449 times
- line-thickness.FCStd
- (52.3 KiB) Downloaded 36 times
Re: Drawing module - Line thickness
line thickness editing works in
OS: Ubuntu 16.04.2 LTS
Version: 0.16.6710 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: f8eca0f9311f07c125dd6742a607724c1fa0b77c
Python version: 2.7.12
OCC version: 6.8.0.oce-0.17
but as you say does not in
Version: 0.17.10993 (Git)
Build type: None
Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291
OCC version: 7.1.0
to test the above I just created a default Part Cube, switched to Draw WB, default A3 page default insert view.
Draw WB is intended to be replaced over time by TechDraw, which is in 0.17
Build type: None
Build type: None
OCC version: 7.1.0
I confirm I encountered the issue only in the recent version of freecad (0.17). Version 0.16 isn't affected.
I understand that in the future Drawing WB will be dismissed, however in this phase a working Drawing WB is helpful to work with old projects.
