Curves workbench
Re: Curves workbench
@Chris_G: some more questions about (sweep_2_rail) <=> Edit: Approximate Points to NURBS.
Working with that tool, one can find some parametrization-options.
- Continuity is almost selfexplaining - are there any recommendations?
- Parametrization grants 4 items - not so clear - a trial and error thing: Any recommendations?
- Smoothing Algorithm - 3 possible Parameters - maybe also a testing and experience thing: Any recommendations?
Hi Chris_G,
I had great success in creating a two-rail surface for the tide-bottle.
Very nice, thank you for the curves workbench:
Best regards
Wilfried
Please have look into this thread:
https://forum.freecadweb.org/viewtopic. ... 62#p204162
I miss G1 at the outside surface:
Best regards
Wilfried
This tool is not sweep_2_rails. It is the approximate tool.hammax wrote: ↑Thu Dec 14, 2017 2:14 pm @Chris_G: some more questions about sweep_2_rail.
One good way to feel how these settings work is to discretize an edge with few points (and eventually change the discretization method to get regularly or not regularly spaced points) and create an approximate curve on them.
You can then check the properties of the approximation curve with a comb plot, and the GeomInfo tool.
Even though there is nothing scientific in this, you end up getting a kind of feeling of the "quality" of the approximation curve :
- how many control points (less is better)
- how the control points are distributed (high-degrees can give CPs that are distributed in a very chaotic way)
Then you can suppose the same will apply to approximation surfaces.
It depends on what you want to do.
C# continuities are mathematical continuities. On a visual point of view, they don't really offer any value over their G# conterparts.
G1 is usually good enough for curves. They will look perfectly smooth. Inkscape only offers C1 continuous paths at best, and that's OK.
But on surfaces (or curves that will be used to generate surfaces later) then G2 will be better, and G3 will offer a visually perfectly smooth surface.
If the points you are approximating are regularly spaced, the parametrization setting will have a very low influence.
The smoothing algo can be pretty interesting but it has some limitation.
It tries to find a curve (or surface) that minimizes the properties according to the supplied weights.
Curve properties :
CL = curve length
CC = curve curvature
CT = curve torsion
Algo settings :
WL = algo length weight
WC = algo curvature weight
XT = algo torsion weight
The algo tries to find the minimal criterion CL*WL + CC*WC + CT*WT
So you assign a high value to torsion weight to get a curve with the least possible torsion, a high value to curvature weight to get a curve with the least possible curvature, etc.
However the algo will not produce a curve or surface with continuity higher than C2.
Nice !freecad-heini-1 wrote: ↑Thu Dec 14, 2017 3:37 pm Hi Chris_G,
Unfortunately, I'm afraid I won't be able to do anything for this.
Sweep-2-rails tool is an approximation tool. It's not a Class-A surfacing tool. You will even be lucky if you get C0 continuity between the 2 halves
Hi Chris,
please can you tell me if there is a way to manipulate the poles from a bspline, or the points of a discetized edge in different axis directions, like to see in this vid at about min 8?
Best regards
Wilfried
Best regards
Wilfried
Unfortunately, I don't have that kind of tool yet.freecad-heini-1 wrote: ↑Sun Dec 17, 2017 10:08 pm Hi Chris,
I would like to do this for a long time now.
But I have never had the courage to give it a try yet.
This will be a rather complex task for me, since it will require some Qt widgets code, along with some Coin3D editing code in the 3D view.
I will first need to convince myself : "Come on, Chris, you CAN do it !"
- microelly2
Yes Sir, you can do it!
You have already a lot of methods for access the coin 3D space,
so it should be possible to get an easier to use tool.
some of my ideas are here
meantime we have learned a lot to get a better tool.
Yes, yes, yes, teamwork.
Please meet over meet.jit.si/freeacd
Take a cold oder hot drink and then start a video conference.
Maybe realthunder and deepsoic are interested to join the video conference for a coffee / tea or beer.
Maybe we can apply such interaction nodes?:
https://forum.freecadweb.org/viewtopic. ... 72#p169625
combining them with widgets is not a big problem:
(ignore the py2 vs py3 stuff, there is no difference between py3 and py2 anymore.)
