Curves workbench
Re: Curves workbench
Rotation_Sweep needs current FreeCAD master.
It is not compatible with latest stable 0.20
I would like to create a Nurbs surface with a number regular segments? Not sure if that is the correct term.
I would then like to use a macro that has as input the Nurbs <surface> and say a small regular <cube>.
The macro would then place a cube ( linked object) at the intersections of the segments
1) I tried to create a Nurbs surface by first selecting a Shape and creating a point cloud using the Points workbench but
the created surface was not very satisfactory see attached 2) I wish to create a surface that is like half an egg, open to suggestions of a better way. The requirement is that the segments are regularly placed in respect of the surface
3) Assuming I can somehow achieve the above, how do I access the intersection points of the segments(?). i.e. the macro has access to the surface object, how do I access the coordinates of the intersections?
Thanks
Not sure that segments is the correct term, what I am after is a surface with a regular grid with respect to the surface?
and then to be able to access the grid points in a macro.
Question : Is there a way of creating a point cloud from a surface? Would seem a fairer challenge than creating a nurbs surface from what is really two surfaces.
Thanks
Are the u,v isoCurves suitable?
Quite possibly, but I need them to be equally displaced in terms of the distances as measured on the surface, looking at the screen shot thatedwilliams16 wrote: ↑Fri Dec 02, 2022 6:35 pm Are the u,v isoCurves suitable?
does not look like the case.
How do I access the coordinates of the intersections?
Small bug:
select the sketch and make a profile give a bopalgo_c0 error.
select the sketch's edge, no error.
same error with joincurves but for both selecting.
- profile_bopalgo.FCStd
- (9.86 KiB) Downloaded 12 times
There is no coordinate system on a curved surface that preserves distances. That's why you can't make a map of the earth that preserves distances.keithsloan52 wrote: ↑Fri Dec 02, 2022 7:00 pmQuite possibly, but I need them to be equally displaced in terms of the distances as measured on the surface, looking at the screen shot thatedwilliams16 wrote: ↑Fri Dec 02, 2022 6:35 pm Are the u,v isoCurves suitable?
Curves|Isocurves draw the lines. Its properties control how many etc.
What do you actually want to do?
Okay I have started work on a macro to process the IsoCurve.keithsloan52 wrote: ↑Fri Dec 02, 2022 7:00 pmQuite possibly, but I need them to be equally displaced in terms of the distances as measured on the surface, looking at the screen shot thatedwilliams16 wrote: ↑Fri Dec 02, 2022 6:35 pm Are the u,v isoCurves suitable?
When the macro processes the selection I can see the TypeId is Part::FeaturePython is there a clean way of determining that I am dealing with an IsoCurve?
With my GDML workbench any Part::FeaturePython object gets a Type set in the Objects.Proxy i.e Objects.Proxy.Type has the type of the FeaturePython.
The user can change Labels so I don't rely on them and specific properties would work but not great for code readability/understanding
You can create the curves directly
doc = App.ActiveDocument
obj = doc.getObject("GDMLEllipsoid")
shp = obj.Shape
sub = obj.getSubObject("Face1")
surf = sub.Surface
umin, umax, vmin, vmax = sub.ParameterRange
nu = 20
ulist = [i*(umax - umin)/nu + umin for i in range(nu+1)]
for u in ulist:
spl = surf.uIso(u)
spl.segment(vmin, vmax)
Part.show(spl.toShape())
Sorry don't like the above, name GDMLEllipsoid is hard coded, different file the object name would be differentedwilliams16 wrote: ↑Fri Dec 02, 2022 9:27 pm You can create the curves directly
doc = App.ActiveDocument obj = doc.getObject("GDMLEllipsoid") shp = obj.Shape sub = obj.getSubObject("Face1") surf = sub.Surface umin, umax, vmin, vmax = sub.ParameterRange nu = 20 ulist = [i*(umax - umin)/nu + umin for i in range(nu+1)] for u in ulist: spl = surf.uIso(u) spl.segment(vmin, vmax) Part.show(spl.toShape())
I want to be able to select an icocurve and another object and act upon those.
Macro currently looks like
print(f"Iso Curves Macro")
sel = Gui.Selection.getSelection()
if len(sel) > 0:
iso = None
surface = None
for s in sel:
print(s.TypeId)
if s.TypeId == "Part::FeaturePython":
print(dir(s))
print(dir(s.Proxy))
So, are you just trying to pick a point on the surface and put something there? Click on the ellipsoid, then
sel = Gui.Selection.getSelectionEx()[0]
point = sel.PickedPoints[0]
surf = sel.SubObjects[0].Surface
u, v = surf.projectPoint(point, 'LowerDistanceParameters')
surf.value(u, v) # => location
surf.normal(u,v) # normal
surf.tangent(u, v) # tangent in u, v directions
