Curves workbench
Chris_G
Re: Curves workbench
Post by Chris_G »
drmacro wrote: Tue Nov 08, 2022 4:49 pm Attempting a sweep on 2 rails with the green edges:
sweep on 2 rails is really old crap.
I would suggest to try Gordon first.
But, indeed, both tools fail at choosing the right circle arc.
By setting the Tolerance of the Freehand_BSplines at 1e-7, it is also possible to use Surface->Fill.
drmacro
Post by drmacro »
Chris_G wrote: Wed Nov 09, 2022 5:52 pm ...
Yes I knew sw2p is old.
I tried it as a fallback after Gordon failed...
The tolerance setting seems to work. I'll proceed with the rest and see if it continues to be the magic sauce.
Thanks!!
drmacro
Post by drmacro »
I was able to complete the surfaces and convert to para solid.
But, Surface and Surface004 fail geo check. Any tips on getting them corrected?
FlattopCamel-2-2.FCStd
(115.58 KiB) Downloaded 31 times
Snip macro screenshot-4010b1.png (118.7 KiB) Viewed 1249 times
Vincent B
Post by Vincent B »
you have forgotten a surface for the solid. ;)
drmacro
Post by drmacro »
Vincent B wrote: Thu Nov 10, 2022 5:37 am you have forgotten a surface for the solid. ;)
The surfaces I mentioned fail geo check on their own...and are the same errors (same face/edge) on them or the solid.
bleber
Post by bleber »
How to make periodic regular b-spline like the screenshot.
I can build the basic shape but the end and the star joint is not regular as other points.
b-spline curves workbench
b-spline draft workbench
bleber wrote: Fri Nov 11, 2022 11:10 pm How to make periodic regular b-spline like the screenshot.
Use addon Parametric Curve FP or 3D Parametric Curve.
hammax
Post by hammax »
... I also found this problem some time ago, but there is no "wiki"
about handling periodic and tangency at the closure ???
pBSpl.FCStd
FC.20.1
(11.09 KiB) Downloaded 18 times
Chris_G
Post by Chris_G »
Unfortunately, OpenCascade doesn't seem to support all types of periodic curve interpolations.
I looked for possible solutions this morning, but without success.
bleber
Post by bleber »
The problem to be a wrong tangency in the junction knot.
