I would like to understand, if possible, why 3 out of 4 of these surfaces are valid. (3 out 4 counting around the, not the bottom and two circles.)
Curves workbench
Re: Curves workbench
using parametric curve.
maybe one day this macro will be embedded in Curves Wb?
- sinus.FCStd
- (25.17 KiB) Downloaded 21 times
- Capture.JPG (17.98 KiB) Viewed 1312 times
My goal is obtain periodic b-spline whiout matematics and parametric.
I can control and maybe can obtain the correct tangency of the first-last knot with parameter "t" (tangent to currant view, I aply with lateral right view)vin edit mode and it apears correct. But there are some other parameter of the knot that controls other things that I not have access.
... i/insert and s/snap work good,
but t/tangent doesn't
and activating p/periodic destroys it
- pBSpl_2.PNG (29.07 KiB) Viewed 1239 times
- pBSpl_2.FCStd
- FC.20.1
- (12.73 KiB) Downloaded 21 times
A screen captures and file.
1 the original curve
2 After apply periodic
3 Side view
4 Apply tangent with view direction (if wrong tangent, try the other side), see the curve symmetry seems correct on these side.
5 result, the tangency appear seems correct, but definitely not.
3 Side view
- knot_problem.FCStd
- (12.6 KiB) Downloaded 25 times
I have found a workaround.
Select the vertexes you want to interpolate and run the following script :
"""Part.BSplineCurve.interpolate() doesn't generate fully periodic curves.
The start/end point has a multiplicity 2 while inner points have a multiplicity 1.
This macro is a workaround.
It duplicates the points we want to interpolate, in order to generate a multi-turn curve
and extracts a one turn BSpline curve in the middle.
import FreeCAD
import FreeCADGui
import Part
def parameterization(points, fac, force_closed=False):
# Computes a knot Sequence for a set of points
# fac (0-1) : parameterization factor
# fac=0 -> Uniform / fac=0.5 -> Centripetal / fac=1.0 -> Chord-Length
pts = points[:]
if force_closed and pts[0].distanceToPoint(pts[-1]) > 1e-7: # we need to add the first point as the end point
pts.append(pts[0])
params = [0]
for i in range(1, len(pts)):
p = pts[i] - pts[i - 1]
if isinstance(p, FreeCAD.Vector):
le = p.Length
else:
le = p.length()
pl = pow(le, fac)
params.append(params[-1] + pl)
return params
# get the selected vertexes
vl = []
sel = Gui.Selection.getSelectionEx()
for so in sel:
svl = []
for sub in so.SubObjects:
if isinstance(sub, Part.Vertex):
svl.append(sub)
if svl:
vl.extend(svl)
svl = []
else:
vl.extend(so.Object.Shape.Vertexes)
# extend the list of points
pts = [v.Point for v in vl]
nbp = len(pts)
n = 1
if nbp <= 4:
n = 2
npts = pts
npts.extend(pts * (2 * n))
nbnp = len(npts)
# interpolate the extended list of points
bs = Part.BSplineCurve()
print(len(npts))
pars = parameterization(npts, 0.5, True)
print(len(npts))
print(len(pars))
bs.interpolate(Points=npts, Parameters=pars, PeriodicFlag=True)
# extract a one turn BSpline curve in the middle
offset = n * nbp
npoles = bs.getPoles()[offset:-offset - 1]
nmults = bs.getMultiplicities()[offset:-offset]
nknots = bs.getKnots()[offset:-offset]
nbs = Part.BSplineCurve()
nbs.buildFromPolesMultsKnots(npoles, nmults, nknots, True, 3)
Part.show(nbs.toShape())
Thank you to make the script.
The scrips works very well !!, but loses the parametric essence.
In the he curve workbench I can attach the curve knots to vertex that I can manipulate. To adjust the curve shape.
Chris_G, many thanks for your help, patience and response to my problem.
Final result (full parametric).
- b-spline periodic.FCStd
- (834.85 KiB) Downloaded 33 times
... I still have problems applying tangency at the "periodic_point".
The space curve is not fully symmetric.
Using a brute force design, to fix the "knot point" gives still some kind of distortion.
The mathematical curve is exact (parametric only by means of geometric construction ??)
- pBSpl.FCStd
- FC.20.1
- (115.7 KiB) Downloaded 27 times
