Curves workbench
Pauvres_honteux
Re: Curves workbench
Post by Pauvres_honteux »
I assume you guys are, naturally, documenting this in an easy understandable way in a publicly accessible place?
Vincent B
Post by Vincent B »
Pauvres_honteux wrote: Wed Apr 14, 2021 8:29 am I assume you guys are, naturally, documenting this in an easy understandable way in a publicly accessible place?
You mean to write a nice documentation. Why not. :)
Vincent B
Post by Vincent B »
As far I looking for, there are not tool to make a 3D parametric Spline from several vertex.
Example: my file to "smooth" the discretized Edge.
Chris, what do you think about that? or I missed the right tool?
AskForBspline.FCStd
(9.65 KiB) Downloaded 43 times
Chris_G
Post by Chris_G »
Interpolation Curve ?
Approximation Curve ?
What do these tools lack ?
Vincent B
Post by Vincent B »
I mean a 3D Bspline. Like the sketcher, but without use it and in 3D.
Just by giving a list of vertex or a wire, the same workflow with interpolated curve.
Pauvres_honteux
GlouGlou wrote: Mon Apr 19, 2021 5:46 pm You mean to write a nice documentation? Why not. :)
If I dare represent the FreeCAD community in this, I'd say you guys are moving the surface and curves programming a good bit forward and upward in a strong manner. Documenting it in a way both mere mortal users, as myself, and other programmers understand would be highly appreciated by us all.
Keep up the good work!
Post by Kunda1 »
Chris_G wrote: Tue Apr 20, 2021 7:20 am
@Chris_G there are some pending PRs on the Curves repo that need attention at your convenience ;)
keithsloan52
Post by keithsloan52 »
The following file has a Bezier Curve created by importing from a 3dm file ( ImportNURBS workbench).
It would be good to be able to edit it, but as far as I can tell all the curves/nurbs workbenches only allow for curves created by themselves
and don't seem to handle standard FreeCADBezier objects :-(
BezierCurve.FCStd
(7.11 KiB) Downloaded 50 times
bartekdko
Post by bartekdko »
hi?
is there any chance to add option to export bspline shapes int single sketch with its position?
that would be perfect to manipulate manually .
maybe it is possible to do it now but I didn't find any
regards
Kundalini.... :idea:
bartekdko wrote: Thu Apr 22, 2021 12:23 am is there any chance to add option to export bspline shapes int single sketch with its position?
Sketches are 2D, and you can convert a 2D B-spline with Draft Draft2Sketch.
