You should have a look at the MangoJelly Solutions Curves workbench series on YouTube. There are 30 videos in the series that explore the workbench and what other workbenches can be used in conjunction.
Curves workbench
Re: Curves workbench
This is done via python, with my work-in-progress code-refactor of BlendSurface.
Indeed, I need to change the icon.
Thanks.
The way the mouse interaction with shapes is currently coded is rather dirty.pafurijaz wrote: ↑Fri Jan 28, 2022 10:43 am I think I miss this possibility to create a B-Spline through the Points, because this would allow to do a manual continuity by constraining the points on construction lines and tangents, and I wanted to ask if you can implement this kind of curve like in Silk.
I don't like it, and I don't wish to work further on that base.
So, that won't happen until I can put together a better shape manipulation library.
i did this 6 years ago with NURBSLib_EVM (which later turned into the Silk addon). so you could probably get a similar result now with Silk.
looks like i also used Part>Shape Builder to close the pointy triangle.
Holy smokes, the file actually opened and built! 6 years later, without the macros available, and through a million FreeCAD versions
slightly different topo, but this could give ideas to rebuild in a different workbench. my goal was to be G2 to the cylinders coming in, and across the midplane of the connector. obviously the flat face gives issues.
edit: i'm just sharing this for ideas, not suggesting using another WB over Curves (Chris, i hope these posts are ok here)
- tri_joint_02.fcstd
- (141.28 KiB) Downloaded 44 times
... stay cool ChrisG, your "customers" are true followers, because your workbench has reached the critical size, is useful and very interesting.
If one looks into the addon manager, there is a nearly babylonian WB-collection
=> after my feeling one of the FC-flaws, it's caused by the multiplicity of developers.
Commercial CADs would combine their sources into theme WBs (and earn their money with downward incompatibility).
FC individualism and different UIs may inhibit such a walk through.
And grant a teasing and interesting participation!!!
LMAO
EDIT: This is the post that generates images below. https://forum.freecadweb.org/viewtopic. ... 10#p566010
Wow fantastic example and code:
Sadly you have not posted images.
From most of your post there is always something to learn. Many many thanks.
Best Regards
Carlo D.
- Various other stuffs.
When using a Freehand B_spline as the path for a Pipeshell what are the squiggly lines and can they be smoothed out?
- Exhaust-w-Curves-1.FCStd
- (658.12 KiB) Downloaded 32 times
