Curves workbench
edwilliams16
Re: Curves workbench
Post by edwilliams16 »
I'm still unclear as to whether you actually want the isocurves (which are curves, not surfaces, they just embody the surface's coordinate lines), or they are a means to an end.
To just generate the cubes in location, per my previous post and onekk's:
doc = App.ActiveDocument
obj = doc.getObject("GDMLEllipsoid")
shp = obj.Shape
sub = obj.getSubObject("Face1")
surf = sub.Surface
umin, umax, vmin, vmax = sub.ParameterRange
nu = 4
ulist = [i*(umax - umin)/nu + umin for i in range(nu+1)]
nv = 4
vlist = [i*(vmax - vmin)/nv + vmin for i in range(nv+1)]
boxLength = 2
for u in ulist:
    for v in vlist:
        base = surf.value(u, v)
        normal = surf.normal(u,v)
        rot = App.Rotation(App.Vector(0,0,1), normal)
        box = Part.makeBox(boxLength, boxLength, boxLength)
        centerpl = App.Placement(-(boxLength/2) * App.Vector(1,1,1), App.Rotation()) # put origin at center of cube
        box.Placement = App.Placement(base, rot) * centerpl
        Part.show(box)
Screen Shot 2022-12-03 at 9.18.02 AM.png (43.42 KiB) Viewed 1130 times
keithsloan52
Post by keithsloan52 »
My Bad : Just looked at code and the IsoCurve object has a property Face, was staring me in the eye all along.
keithsloan52
edwilliams16 wrote: Sat Dec 03, 2022 7:19 pm I'm still unclear as to whether you actually want the isocurves (which are curves, not surfaces, they just embody the surface's coordinate lines), or they are a means to an end.
They are a means to an end, I am trying to code a macro that in effect takes two parameters, i.e two things are selected and then the macro is run.
The two things are 1) an IsoCurve created by the curves workbench 2) A GDML Object.
The purpose is to create an Array of GDML Objects at the intersection points of IsoLines
The end result is the Array of GDML Objects.
Creating a surface and using IsoCurves is just a means to an end the Array of Objects, after that
the surface and IsoCurve could be deleted and it only of use if the user wants to change things that they have any purpose after creation.
I only want to pass to the macro a selected IsoCurve Object and a GDML Object, I want to avoid having to pass anything else.
>>> doc = App.getDocument("IsoCurve_Test")
>>> obj = doc.getObject("IsoCurve")
>>> shp = obj.Shape
>>> shp = obj.Shape
>>> ### End command Std_SendToPythonConsole
>>> print(obj.Face)
(<Part::PartFeature>, ['Face1'])
>>> print(obj.Face[0])
<Part::PartFeature>
>>> print(obj.Face[1])
['Face1']
>>> faceObj=obj.Face[0]
>>> faceName = obj.Face[1]
>>> sub=faceObj.getSubObject(faceName)
>>> print(dir(sub))
['__add__', '__class__', '__class_getitem__', '__contains__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__getitem__', '__getnewargs__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__iter__', '__le__', '__len__', '__lt__', '__mul__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__rmul__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'count', 'index']
>>> print(sub.Surface)
AttributeError: 'tuple' object has no attribute 'Surface'
If I try something similar to your code with the info in the IsoCurve.
I think the Face info in the IsoCurve i.e. IsoCurve.Face[0] is a Linked Object and I suspect I have to do something to be able to access the "source" object and have done something similar in the past but cannot remember the details.
keithsloan52
Think of the surface creation and isocurves as just part of the design/specification process, the desired end result is an array of GDML Objects
at the intersection of the isolines.
onekk
Post by onekk »
Notvsure if it help but when you accessed the subobject you have an error saying that a tuple object has not this property.
But as a tuple sub[0] will return the object, maybe this is the Face?
or try to print the sub object and see what is.
For other considerations sadly I'm on mobile now.
Regards
Carlo D.
- Various other stuffs.
keithsloan52
onekk wrote: Sat Dec 03, 2022 9:36 pm Notvsure if it help but when you accessed the subobject you have an error saying that a tuple object has not this property.
Regards
Carlo D.
Thanks Carlo
Least that gets me a Surface from the IsoCurve but code is not there, will look again tomorrow.
Main function is now
def arrayIsoIntersections(iso, obj):
	import DraftGeomUtils as dgmu
	print("Array at IsoCurve Intersections")
	print("IsoCurve")
	print(dir(iso))
	print(f"Number U {iso.NumberU} Number V {iso.NumberV}")
	print("IsoCurve Shape")
	print(dir(iso.Shape))
	print(f"Number of isoCurve Faces {len(iso.Shape.Faces)}")
	parent = getParent(obj)
	lnkObj = False
	faceObj = iso.Face[0]
	faceName = iso.Face[1]
	sub = faceObj.getSubObject(faceName)
	surf = sub[0].Surface
	for u in range(0, iso.NumberU):
		for v in range(0, iso.NumberV):
			base = surf.value(u,v)
			rot = FreeCAD.Rotation(FreeCAD.Vector(0,0,1), normal)
			if lnkObj:
				new = parent.newObject("App::Link","Link_"+obj.Name)
				new.LinkedObject = obj
				new.LinkPlacement.Base = base
				new.LinkPlacement.Rotation = rot
			else:
				obj.Placement.Base = base
				obj.Placement.Rotation = rot
				lnkObj = True
edwilliams16
keithsloan52 wrote: Sat Dec 03, 2022 8:38 pm
Let me say it AGAIN. An isoCurve has NO FACES. It consists only of edges, because it is just a collection of curves. (If you check the Faces property, you'll find it is an empty list.)
If you pass your routine the ellipsoidal surface and the object and somehow provide an array of u-values and v-values, you can place the objects at the intersection in the manner I just posted.
It is possible to find the normal direction at the intersection of two isolines. It is the cross product of the tangent vectors of the two curves - but this is a very roundabout way of obtaining information that was directly available from the surface, itself. The only purpose IMO for the Isolines object is for visualization.
keithsloan52
edwilliams16 wrote: Sat Dec 03, 2022 10:25 pm Let me say it AGAIN. An isoCurve has NO FACES. It consists only of edges, because it is just a collection of curves. (If you check the Faces property, you'll find it is an empty list.)
Sorry but I don't think you are correct - If you look at the isoCurve Objects Properties it has a property called "Face" it is a list of two items.
GDMLEllipsoid and "Face1"
It has at least info on the Face used to create the IsoCurve.
The isoCurve objects Shape just has edges.
edwilliams16
keithsloan52 wrote: Sat Dec 03, 2022 10:33 pm
Agreed. I thought we were talking about the (shape) content of isoCurves and trying to find the normal vector from them.
You can retrieve the face of the ellipsoid with
ob, fa = obj.Face
face = getattr(ob.Shape, fa[0])
Then you can continue with my code. You will of course retrieve obj via selection.
keithsloan52
edwilliams16 wrote: Sat Dec 03, 2022 11:08 pm
ob, fa = obj.Face
Okay I tried that but not sure how I get to access the surface
currently have surf = face.Faces[0].Surface
	print("IsoCurve")
	print(dir(iso))
	lnkObj = False
	faceObj, faceNames = iso.Face
	#faceObj = iso.Face[0]
	#faceName = iso.Face[1]
	face = getattr(faceObj.Shape, faceNames[0])
	#sub = faceObj.getSubObject(faceName)
	#surf = sub[0].Surface
			if lnkObj:
			else:
				lnkObj = True
See also python console
>>> shp = obj.Shape
>>> ob, fa = obj.Face
>>> print(dir(face))
['Area', 'BoundBox', 'CenterOfGravity', 'CenterOfMass', 'CompSolids', 'Compounds', 'Content', 'Edges', 'Faces', 'Length', 'Mass', 'MatrixOfInertia', 'MemSize', 'Module', 'Orientation', 'OuterWire', 'ParameterRange', 'Placement', 'PrincipalProperties', 'ShapeType', 'Shells', 'Solids', 'StaticMoments', 'SubShapes', 'Surface', 'Tag', 'Tolerance', 'TypeId', 'Vertexes', 'Volume', 'Wire', 'Wires', '__class__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__getstate__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__setstate__', '__sizeof__', '__str__', '__subclasshook__', 'addWire', 'ancestorsOfType', 'applyRotation', 'applyTranslation', 'check', 'childShapes', 'cleaned', 'common', 'complement', 'copy', 'countElement', 'countSubElements', 'curvatureAt', 'curveOnSurface', 'cut', 'cutHoles', 'defeaturing', 'derivative1At', 'derivative2At', 'distToShape', 'dumpContent', 'dumpToString', 'exportBinary', 'exportBrep', 'exportBrepToString', 'exportIges', 'exportStep', 'exportStl', 'extrude', 'findPlane', 'fix', 'fixTolerance', 'fuse', 'generalFuse', 'getAllDerivedFrom', 'getElement', 'getElementTypes', 'getFaces', 'getFacesFromSubElement', 'getLines', 'getLinesFromSubElement', 'getPoints', 'getTolerance', 'getUVNodes', 'globalTolerance', 'hashCode', 'importBinary', 'importBrep', 'importBrepFromString', 'inTolerance', 'isClosed', 'isCoplanar', 'isDerivedFrom', 'isEqual', 'isInfinite', 'isInside', 'isNull', 'isPartOfDomain', 'isPartner', 'isSame', 'isValid', 'limitTolerance', 'makeChamfer', 'makeEvolved', 'makeFillet', 'makeHalfSpace', 'makeOffset', 'makeOffset2D', 'makeOffsetShape', 'makeParallelProjection', 'makePerspectiveProjection', 'makeShapeFromMesh', 'makeThickness', 'makeWires', 'mirror', 'multiFuse', 'normalAt', 'nullify', 'oldFuse', 'optimalBoundingBox', 'overTolerance', 'project', 'proximity', 'read', 'reflectLines', 'removeInternalWires', 'removeShape', 'removeSplitter', 'replaceShape', 'restoreContent', 'reverse', 'reversed', 'revolve', 'rotate', 'rotated', 'scale', 'scaled', 'section', 'sewShape', 'slice', 'slices', 'tangentAt', 'tessellate', 'toNurbs', 'transformGeometry', 'transformShape', 'transformed', 'translate', 'translated', 'validate', 'valueAt', 'writeInventor']
>>> print(face.SubShapes)
[<Wire object at 0x60000b217280>]
>>> print(face.Faces)
[<Face object at 0x60000b215780>]
>>> print(dir(face.Faces))
['__add__', '__class__', '__class_getitem__', '__contains__', '__delattr__', '__delitem__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__getitem__', '__gt__', '__hash__', '__iadd__', '__imul__', '__init__', '__init_subclass__', '__iter__', '__le__', '__len__', '__lt__', '__mul__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__reversed__', '__rmul__', '__setattr__', '__setitem__', '__sizeof__', '__str__', '__subclasshook__', 'append', 'clear', 'copy', 'count', 'extend', 'index', 'insert', 'pop', 'remove', 'reverse', 'sort']
>>> print(dir(face.Faces[0]))
Result still looks like
Test file before
IsoCurve_Test.FCStd
(161.27 KiB) Downloaded 16 times
Latest Macro
Test-ISO-B.FCMacro
(2.47 KiB) Downloaded 14 times
