Curves workbench
Ramses
Re: Curves workbench
Post by Ramses »
Curve on surface works fine when loft is just a surface, not when it's a solid.
With the last CurvesWB
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.20.25541 (Git) AppImage
Hash: ca043dcb6d20d70b8e24d75e810683214eecc5d4
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: French/France (fr_FR)
curve_on_surface_loft.FCStd
(28.72 KiB) Downloaded 43 times
Post by Kunda1 »
Off-topic but related:
OCC upstream has fixed a bug that I wonder has any implication on Curves ?
https://github.com/Open-Cascade-SAS/OCC ... 3e720d6e97
0026979: Parabola curve intersection with variety of surfaces produces incorrect results.
Method Intf_Tool::ParabBox now properly estimates the number of segments for a 3D parabola.
Fix input arguments of called Bnd_Box::Get method in Intf_Tool::HyprBox method.
Sabm01
Post by Sabm01 »
Potential bug in approximate.
My configuration :
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/Canada (fr_CA)
with last version of CurvesWB.
To replicate the bug :
  • Create a Groupe.
    Create 2 bsplines in 2 sketchs.
    Discretize the 2 curves.
    Approximate the Groupe to obtain a surface.
    Save the file then you obtain the message :
09:56:53 PropertyPythonObject::toString(): failed for <class 'freecad.Curves.approximate.Approximate'>
09:56:53 Traceback (most recent call last):
File "C:\Program Files\FreeCAD 0.19\bin\lib\json\__init__.py", line 231, in dumps
return _default_encoder.encode(obj)
File "C:\Program Files\FreeCAD 0.19\bin\lib\json\encoder.py", line 199, in encode
chunks = self.iterencode(o, _one_shot=True)
File "C:\Program Files\FreeCAD 0.19\bin\lib\json\encoder.py", line 257, in iterencode
return _iterencode(o, 0)
File "C:\Program Files\FreeCAD 0.19\bin\lib\json\encoder.py", line 179, in default
raise TypeError(f'Object of type {o.__class__.__name__} '
<class 'TypeError'>: Object of type FeaturePython is not JSON serializable
10:08:17 PropertyPythonObject::toString(): failed for <class 'freecad.Curves.approximate.Approximate'>
10:08:17 Traceback (most recent call last):
The test file is provided.
Thanks for your time,
Michel
test1.FCStd
(24.33 KiB) Downloaded 47 times
Michel Sabourin (Sabm01)
www.simturb.com
Sabm01
Post by Sabm01 »
Sabm01 wrote: Mon Aug 30, 2021 3:02 pm Potential bug in approximate.
Consequential problem.
Reading the file test1.FCStd then modifying the Approximate_Surface Parametrization to Curvilinear we obtain:
19:23:32 Traceback (most recent call last):
File "C:\Users\miche\AppData\Roaming\FreeCAD\Mod\Curves\freecad\Curves\approximate.py", line 204, in execute
num = len(self.Points)
<class 'AttributeError'>: 'Approximate' object has no attribute 'Points'
19:23:42 Traceback (most recent call last):
Similar behavior has been raised recently by :
byteofsoren wrote: Sat Aug 07, 2021 2:26 pm Hi. I think I found a bug.
When I reopen a file that uses rails I get
File "/home/magnus/.FreeCAD/Mod/Curves/freecad/Curves/approximate.py", line 204, in execute
15:24:03  Recompute failed! Please check report view.
Hope that this helps.
Thanks for your support,
Michel
www.simturb.com
Chris_G
Post by Chris_G »
Sabm01 wrote: Mon Aug 30, 2021 11:31 pm Reading the file test1.FCStd then modifying the Approximate_Surface Parametrization to Curvilinear we obtain ...
I think it is fixed now.
Could you please update the workbench and retry, please.
Sabm01
Post by Sabm01 »
Chris_G wrote: Tue Aug 31, 2021 2:33 pm
Thank you very much Chris, problem solved!
Moreover, I advise you that I will publish, in the next days, a new workbench based on CurvesWB to design blades for turbine, fan, compressor, pump, etc. It is, for me, a 2 years work.
Documentation is already available at
https://michelsabourin.scenari-communit ... trace.html
Yes, it is in french but using browser translator like MS Edge gives a very good result.
I will verify the robustness of solid and body creation. Up to now, it was not perfectly reliable. Anyway, it is coming.
I will need your comments and support.
Thank you again,
Michel
www.simturb.com
Chris_G
Post by Chris_G »
Sabm01 wrote: Tue Aug 31, 2021 3:18 pm Moreover, I advise you that I will publish, in the next days, a new workbench based on CurvesWB to design blades for turbine, fan, compressor, pump, etc. It is, for me, a 2 years work.
As indicated on Curves workbench Github repository :
This workbench is in ALPHA state and should NOT be used for any serious work.
Therefor, making your own workbench depend on Curves WB, is not a good idea.
I think you'd better copy the CurvesWB files that you use to your own workbench.
Ramses
Post by Ramses »
Hello
Is someone able to give an answer to my post Thu Aug 26, 2021 8:05 pm .
Thanks a lot for the time you spend.
Vincent B
Post by Vincent B »
Hi Chris,
HQ Ruled surface is vanished? :roll:
Chris_G
Post by Chris_G »
It was not working good. I removed it for now.
