Curves workbench
Re: Curves workbench
Give a try at Gordon surface.
Sweep on 2 rails is old and deprecated.
... or do it KISS with a simple Loft in PartWB.
Degree of Loft is variable.
Also more than 3 profiles give a controllable shape.
If more complex, use sketches instead of quick and dirty scaled clones.
If still more complex then use Gordon.
- Loft_no_overshoot.FCStd
- FC.18.4
- (13.82 KiB) Downloaded 37 times
Thanks both for the speedy responses - Gordon curve has solved my 'simplest case' example. It doesn't work on my more complex example, but I need to put some work into that to work out why it won't draw a curve before I ask for help.
This means we should ignore it ?
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Designer | Faculty
This means :
- Try Gordon surface first, it is smarter, more general, and has better precision.
- If Gordon surface fails, give a try at SweepOn2Rails, but I don't think it has any advantage against Gordon surface.
Do you think it’s is possible to add g1 G2 to the Gordon surface
This would perfect this curve network tool
Designer | Faculty
Designer | Faculty
It sounds like a very exciting challenge, but I won't have time to work on this for now.
Lets track the issue on the curves workbench repo then?
... with some effort Gordon also could be tamed, by adding adjustable net lines via Interpolation_Curve.
- No_overshoot.FCStd
- FC.18.4
- (42.08 KiB) Downloaded 41 times
