Curves workbench
Re: Curves workbench
...Chris_B's curveWB is a real bringer.
I tried sail-design again, this time with learningcurve. Bendt mast, sail-transition to straight boom, leeward swept trailing edge, all in.
You can use wires AND sketches for profiles and rails...
- Sail_0.FCStd
- (53.63 KiB) Downloaded 170 times
With the second part of that statement you sure are right, but the first part is awfully wrong. I feel honoured, but this Workbench is from Chris_G.
ChrisB
100% agreement!
I wonder how to change the number of bspline poles. It's so easy because it's possible to exchainge a sketch completely new.
Look at sketch003. I edit the sketch, draw a new bspline with more poles, deleted the old one - the result - a full parametric new surface. Whow - that is really a great workbench!
What about the guitar maker here?
The tiede bottle is reachable:
https://www.youtube.com/watch?v=FnuxoUltj_I
The missing piece, from my point of view, the possibility to define tangent constraint to neighbor surfaces.
Best regards
Wilfried
- Chris_G_curve-WB-exchange-sketch.png (125.8 KiB) Viewed 6921 times
Thanks for the kind words.
I don't have much time these last days.
But here is the latest tool : a blendSurface.
First, you need to create a "Curve on Surface" object.
The tool needs a face and an edge selected. The green lines show the normals along the edge.
The blue lines show the Binormals along the edge.
They can be reversed in the properties, if desired..
By selecting 2 "Curve on Surface" objects, you can create a blendSurface : That surface can be approximated by a face, the same way as for Sweep2Rails.
This surface is "approximately" tangent to the 2 generating faces.
I say "approximately" because (same as SweepOn2Rails) the process involves some sampling / approximating, so the tolerance depends on the number of samples and approximation tolerance.
Funny, it is even easy to "reconstruct" a kind of torus from the initial face of the screenshots :
...you get even more funny results, if you change the orientations of the normals/binormals.
Only problem is, if the body is moved away by replacement, the blend always remains at the original Position.
...I also tried to do some airfol-to-hull-blemd (Yak-example).
But at the trailingedge there is a crossover in the wireframegrid. Maybe thats the cause FC got into endless calculation.
This is why I keep the surface creation as a separate final step.
So, when you see that kind of bad result, you get a chance to not put FC into an endless loop.
And it looks like the blendSurface will need more work before it can work on that kind of test case.
- microelly2
It's a common problem to get good borders for BSpline surfaces.
I add two extra rows of poles , calculate the surface and then delete the outer segments with the artefacts.
Doing the same for the other surface brings the edges together.
the problem is to get a good top
here the surface is cutted and a new top surface is created which fits the middle shoe
