Curves workbench
Re: Curves workbench
Perfect like this
- Surface2Make3.FCStd
- (626.14 KiB) Downloaded 61 times
- Capture.JPG (76.93 KiB) Viewed 2009 times
Could someone give me a step by step on using snapping in create freehand bspline tool?
It is eluding me.
I'm attempting to snap the mid vertex of a new bspline on a profile (the profile happens to be in a sketch).
I get the bspline point moving at a distance to the cursor, and the report view keep repeating "snapping to none".
Edit: Got it! select the vertex of the spline, and ctrl-click the target vertex (or edge) and THEN hit s. Duh.
It is eluding me.
Sooo...when I open this file the following is displayed:
And, before or after deleting the broken Gordon surface I can't select the line circles in red:
File "/home/mac/.FreeCAD/Mod/Curves/freecad/Curves/Discretize.py", line 219, in __setstate__
self.obj = FreeCAD.ActiveDocument.getObject(state["name"])
<class 'KeyError'>: ('name',)
08:52:14 Traceback (most recent call last):
08:52:14 SketchObject::onChanged(): Unmanaged change of Constraint Property results in invalid constraint indices
- In and out garbage_OOTB-1.FCStd
- (27.62 KiB) Downloaded 51 times
Did you update the workbench recently ? This should not appear with current version.drmacro wrote: ↑Mon Jun 07, 2021 1:00 pm Sooo...when I open this file the following is displayed:
Traceback (most recent call last): File "/home/mac/.FreeCAD/Mod/Curves/freecad/Curves/Discretize.py", line 219, in __setstate__ self.obj = FreeCAD.ActiveDocument.getObject(state["name"]) <class 'KeyError'>: ('name',) ...
In the View Properties, "Selectable" is set to False for this curve.
Addon Mangler says it's up to date (Note: this on local built 0.20 master...if that makes a difference.)
Ok...but, I created this spline. I didn't set it that way....
Is it possible that it got toggled some how when I was attempting figure out how to use the 's' snap keyboard shortcut?
What does this mean? (Same file after some addition splines, but no change to the discretized lines.)
PropertyPythonObject::toString(): failed for <class 'freecad.Curves.Discretize.Discretization'>
11:54:16 Traceback (most recent call last):
File "/home/mac/.FreeCAD/Mod/Curves/freecad/Curves/Discretize.py", line 213, in __getstate__
out = {"name": self.obj.Name,
<class 'AttributeError'>: 'Discretization' object has no attribute 'obj'
11:54:16 PropertyPythonObject::toString(): failed for <class 'freecad.Curves.Discretize.Discretization'>
The Selectable property is toggled when entering / leaving edit mode.
So I suppose it may stay to False, if edit mode is not (or improperly) exited.
It definitely means that the workbench is not up-to-date.
Maybe you can uninstall / re-install ?
Thanks!
Looks like uninstall/re-install fixed it.
I am sorry for the slight off-topic. But I've spent a few hours, scratching my head how you got that smooth surface. If I delete your surface.filling and make my own, I can't get it to be continuos, even with the non-boundary edge added.
I noticed that the surfaces you made had different Boundary Faces and Boundary Order.
Yours Mine
But I don't seem to be able to edit those (I get a hard crash)
Please help?
In the Surface.Filling UI, in the list of boundary edges, you can double-click an edge to choose its attached face and G1 continuity.
