Curves workbench
Re: Curves workbench
To avoid self-intersection, it is generally better to choose the steepest and shortest Sweep path possible.
- Manifold_2.FCStd
- (324.67 KiB) Downloaded 61 times
I'll do that. It makes sense - create line then bind it into model and then use link in model.
Both inside and outside surfaces look fine in my version of FC, and my Slicer accepted it as all clear. I'll see what the printer makes of it.
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
Updated Wb, and Curve On Surface is vanished?
It was only used by BlendSurface.
And BlendSurface has been totally rewritten, so that it takes directly Edge1, Face1, Edge2, Face2 as input selection.
But I only removed it from Gui toolbar; old project files can still load CurveOnSurface objects.
Did you use it for another purpose than BlendSurface ?
you mean curves on surface?
It was usefull: "ribs" (bordure ou rebord en français), offset a curve on a surface....
not only for blend surface.
OK, then I'll restore it in the toolbar.
EDIT : OK, Done. Funny enough, it seems you use the workbench more than I do myself
Thanks, I will show two examples.
Here.
- offset.FCStd
- (29.53 KiB) Downloaded 65 times
- Ribs.FCStd
- (31.53 KiB) Downloaded 69 times
Hello, ive got problem with Curves workbench. Ive downloaded via Addon Manager -> installed-> restarted app.. After clicking to Curves Workbench i got error: 15:39:30 Traceback (most recent call last):
File "C:\Users\LIS\AppData\Roaming\FreeCAD\Mod\CurvesWB-master\freecad\Curves\init_gui.py", line 32, in Initialize
from . import ParametricBlendCurve # cleaned
File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
File "C:\Users\LIS\AppData\Roaming\FreeCAD\Mod\CurvesWB-master\freecad\Curves\ParametricBlendCurve.py", line 17, in <module>
from freecad.Curves import blend_curve
File "C:\Users\LIS\AppData\Roaming\FreeCAD\Mod\CurvesWB-master\freecad\Curves\blend_curve.py", line 24, in <module>
from scipy.optimize import minimize
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\optimize\__init__.py", line 387, in <module>
from .optimize import *
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\optimize\optimize.py", line 36, in <module>
from ._numdiff import approx_derivative
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\optimize\_numdiff.py", line 6, in <module>
from scipy.sparse.linalg import LinearOperator
i work on win 10.
Glad if anyone would help. Thanks in advance
i work on win 10.
What result do you get if you type this in the python console ?
Also, please post you FreeCAD info.
