Curves workbench
Re: Curves workbench
Variable offset3D of a surface with curves on surface.
- variable_thickness.FCStd
- (489.64 KiB) Downloaded 71 times
OK, that's a nice use case. Great job !
DiscretizeEdge seems have a small bug with circular edge: trying to get 4 vertexes, but only 3 coming up. Probably because the first and last is mixed up?
- discretize_bug.FCStd
- (5.31 KiB) Downloaded 58 times
- Capture.JPG (37.92 KiB) Viewed 2230 times
And Segment Surface seems bugging too when used with discretized curve. Trying to get 4 faces but only 3 are created.
- Capture.JPG (47.84 KiB) Viewed 2228 times
Fixed.
When you modify something of Curves wb, the Addon manager tool does not show it, it does not give the option to update. Not a big problem, delete the Curves folder (C:\Users\HK\AppData\Roaming\FreeCAD\Mod\Curves) then open FreeCAD, the Addon manager, reinstall and you have the latest Curves WB.
It also happens that when installing manually with Git (https ://github.com/tomate44/CurvesWB.git) the name of the folder created in its path is "CurvesWB". Then when opening FreeCAD, Curves workbench is there, everything works fine. But then open Addon Manager and Curves workbench is not install. If you also install from Addon manager then you have two folders, one is "Curves" and another is "CurvesWB". It is also not a big problem because everything works fine.
I do not know if you were aware of this behavior, I just wanted to report in case it would be good for you.
Cheers!
OS: Windows 10 (10.0)
Version: 0.19.24291 (Git)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: Spanish/Spain (es_ES)
Cheers!
Qt version: 5.12.9
OCC version: 7.4.0
Ok for discretize.
But segment surface still have some troubles with a cylinder:
- surfaces carried out are inverted (sometimes)
- surfaces doesn't follow discretized edge very well (maybe after changing number of descretize points)
- surfaces have bop algo error C0 -> can't use them for offset3D. but not all: the surface poles number change.
- seg_surf.FCStd
- (17.23 KiB) Downloaded 55 times
- Capture.JPG (97.36 KiB) Viewed 2077 times
Do you mean that ive have to open cmd and then start python console? if yes , then when ive input "from scipy.optimize import minimize" ive received thisChris_G wrote: ↑Thu May 13, 2021 7:18 am Hello,
What result do you get if you type this in the python console ?Also, please post you FreeCAD info.Code: Select all
Traceback (most recent call last);
File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'scipy"
Iam using Freecad 0.19.
Thanks for your help
No, I mean FreeCAD's python console.
oh ok, then ... this full rep after imput
Python 3.8.6+ (heads/3.8-dirty:a12f459ec2, Nov 5 2020, 12:01:10) [MSC v.1927 64 bit (AMD64)] on win32
Type 'help', 'copyright', 'credits' or 'license' for more information.
>>> Gui.runCommand('Std_Workbench',22)
>>> Gui.runCommand('Std_ViewStatusBar',1)
File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\optimize\__init__.py", line 387, in <module>
from .optimize import *
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\optimize\optimize.py", line 36, in <module>
from ._numdiff import approx_derivative
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\optimize\_numdiff.py", line 6, in <module>
from scipy.sparse.linalg import LinearOperator
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\sparse\__init__.py", line 227, in <module>
from .base import *
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\sparse\base.py", line 4, in <module>
from .sputils import (isdense, isscalarlike, isintlike,
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\sparse\sputils.py", line 8, in <module>
from scipy._lib._util import prod
File "C:\Program Files\FreeCAD 0.19\bin\lib\site-packages\scipy\_lib\_util.py", line 7, in <module>
from multiprocessing import Pool
File "C:\Users\LIS\AppData\Roaming\FreeCAD\Mod\retr3d\multiprocessing\__init__.py", line 64, in <module>
from multiprocessing.process import Process, current_process, active_children
File "C:\Users\LIS\AppData\Roaming\FreeCAD\Mod\retr3d\multiprocessing\process.py", line 262
except SystemExit, e:
SyntaxError: invalid syntax
