I have the same error.Cropduster wrote: ↑Mon Nov 28, 2022 6:50 pm Thanks Chris_G, operating the Interpolate feature on the same file still did not work, but I notice the error lines are different from previous. So, is this associated with some aspect of Ubuntu I haven't installed/updated?
18:44:20 Running the Python command 'Interpolate' failed:
File "/home/brianw/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/interpolate.py", line 342, in Activated
source = self.parseSel(s)
File "/home/brianw/.local/share/FreeCAD/Mod/Curves/./freecad/Curves/interpolate.py", line 333, in parseSel
verts = obj.Object
'Sketcher.SketchObject' object has no attribute 'Object'
Curves workbench
Re: Curves workbench
OK. New fix. Please try again.
Thanks Chris_G, updated to 0.6.2 but alas it didn't work. Attached is a screenshot after I used the Approximate Tool: the Interpolate tool produced the text shown in the Report view.
- Screenshot from 2022-11-29 17-25-41.jpg (140.9 KiB) Viewed 949 times
I forgot to push the fix. Done
Please try again with version 0.6.3
Thanks Chris_G, the update did produce a result this time, but not as expected. I was trying to connect the ends of the lines in the x-direction including the 1st point up the z-axis from the origin (lowest point). They were selected in sequence and produces the same result which ever the direction. Maybe the attached screenshot might help.
- Screenshot from 2022-11-29 19-59-29.jpg (144.59 KiB) Viewed 902 times
OK, so I reverted the latest changes that were not compatible with current FreeCAD Stable 0.20Cropduster wrote: ↑Tue Nov 29, 2022 8:09 pm Thanks Chris_G, the update did produce a result this time, but not as expected. I was trying to connect the ends of the lines in the x-direction including the 1st point up the z-axis from the origin (lowest point). They were selected in sequence and produces the same result which ever the direction. Maybe the attached screenshot might help.
Please update Curves to 0.6.4 and try again.
Thanks Chris_G, It doesn't look like v0.6.4 is available yet. My FreeCAD Addon Manager only shows v0.6.3
Silly me.
I have again forgot to push the fix.
I definitely shouldn't challenge my single-thread brain.
Chris_G, Many thanks, it works. Thanks for your patience and persistence.
... thanks, Interpolation_Curve works again,
but Rotation_Sweep still doesn't (every day at least one trial!)
- test_rotationSWeep_H.FCStd
- FC.20.1
- (49.3 KiB) Downloaded 19 times
