Curves workbench
Cekuhnen
Re: Curves WB : New BlendSolid tool
Post by Cekuhnen »
Chris_G wrote: Sat Jul 24, 2021 10:51 am I have added a new tool to the Curves Workbench.
It is called BlendSolid.
The goal is to join 2 solids by a selected face, with smooth continuity.
I woke up to see what's new - this came out of no where !
Chris G this is so amazing - I use such a tool a lot and it is so important to make transitional parts !
How can we test it ?
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Chris_G
Re: Curves workbench
Post by Chris_G »
Update the workbench, and you should have access to the new tool.
blendsolid_test.FCStd
(252.31 KiB) Downloaded 55 times
Cekuhnen
Post by Cekuhnen »
Oh that’s how that works - fantastic
I Chris B
I got this also with this new tool. Other Chris pointed out some error in the dependency graph which show up after adding the loft.
I attached the file in case it helps to figure out what causes the issue.
BlendSolid.FCStd
(194.1 KiB) Downloaded 47 times
Designer | Faculty
Cekuhnen
Post by Cekuhnen »
Here is another interesting result
the edges do not remain tangent while the are in the sketches
I attached the file
BLENDLOFTSOLID.FCStd
(282.04 KiB) Downloaded 41 times
Designer | Faculty
Chris_G
Post by Chris_G »
Cekuhnen wrote: Sat Jul 24, 2021 12:15 pm I got this also with this new tool. Other Chris pointed out some error in the dependency graph which show up after adding the loft.
I think the bug comes from BlendSurface. I have already seen this kind of failure.
I have to investigate.
The "Links goes outside of the allowed scope" is more a warning than an error.
It happens a lot if you use Curves WB tools on PartDesign objects.
Curves WB was not designed to be used with PartDesign objects.
Cekuhnen wrote: Sat Jul 24, 2021 1:18 pm Here is another interesting result
Unfortunately, continuity is not supported between the consecutive Blend Surfaces.
Cekuhnen
Post by Cekuhnen »
Chris_G wrote: Sat Jul 24, 2021 1:56 pm It happens a lot if you use Curves WB tools on PartDesign objects.
ah very useful to know
What about part design ? Projecting onto part design shell surfaces seems to be hit or miss
Designer | Faculty
Chris_G
Post by Chris_G »
I have added a Fuse option to BlendSolid, in the Settings group.
When enabled, the blendsolid will be fused with the 2 source solids; these 2 objects will become children of the blendsolid in the TreeView, and the Shape Status will display "Fused".
Cekuhnen
Post by Cekuhnen »
Chris_G wrote: Tue Jul 27, 2021 4:33 pm I have added a Fuse option to BlendSolid, in the Settings group.
Top Notch !
Designer | Faculty
Post by Kunda1 »
+1
Vincent B
Post by Vincent B »
Another thing to keep. ;) great.
