Curves workbench
saso
Re: Curves workbench
Post by saso »
Chris_G wrote: Sun Jun 26, 2022 10:27 am I increased version number to 0.5
Is it good now ?
Hmm, it is a bit strange because, the addon manager did see the update and after the update I can also see the new files in the Mod folder, but I don't see for example the new Flatten icon the menu or toolbar... ? :?
OS: Windows 10 (10.0)
Version: 0.21.29277 (Git)
Hash: ad0f1147f74d8e010d47cfca2bb08033e0f3b4ae
Python 3.8.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Locale: Slovenian/Slovenia (sl_SI)
Installed mods:
* CfdOF 1.17.0
* Curves 0.5.0
* DynamicData 2.46.0
* FEM_FrontISTR 0.1.0
* lattice2 1.0.0
* Plot 2022.4.17
Chris_G
Post by Chris_G »
Did you restart FC ?
thomas-neemann
Post by thomas-neemann »
is it possible to flatten these surface
test1213.FCStd
(16.05 KiB) Downloaded 32 times
in curves?
source: https://forum.freecadweb.org/viewtopic.php?f=13&t=69864
saso
Post by saso »
Chris_G wrote: Wed Jun 29, 2022 10:11 am Did you restart FC ?
yes, and I also don't see it in other FC versions 0.19, 0.20 and I see no errors in report or console
saso
Post by saso »
thomas-neemann wrote: Wed Jun 29, 2022 10:17 am is it possible to flatten these surface
this is the case that was discussed in the previous page of this topic, the surface is not explicitly defined/detected as a cylindrical or conical face and so the flatten tool does not work on it, at least not at the moment, it would have to be extended to support such cases. but the mesh method should work and also give quite good results in such cases where the face is actually developable.
rock.vice
Post by rock.vice »
Is it good now ?
Is this version intended only for 0.21_weekly_build? My add on manager is reporting 0.4.4 as the last update available for the branch master, but the system info is reporting that the 0.5.0 is already installed.
OS: KDE neon User - 5.25 (KDE/plasma)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * Manipulator 1.4.5
  * Assembly4 0.12.0
  * Ship 2022.4.11
  * Assembly3 0.11.3
  * sheetmetal 0.2.49
  * Curves 0.5.0
  * freecad-mbdyn-dynamics-workbench-master
  * A2plus 0.4.56a
  * Silk 1.0.0
  * fcgear 1.0.0
  * CfdOF 1.17.0
  * lattice2 1.0.0
  * fasteners 0.3.46
  * Plot 2022.4.17
Thank you in advance
saso
Post by saso »
rock.vice wrote: Wed Jun 29, 2022 11:09 am Is this version intended only for 0.21_weekly_build? My add on manager is reporting 0.4.4 as the last update available for the branch master, but the system info is reporting that the 0.5.0 is already installed.
It should work in all recent versions, try to run the "refresh local cache" command in the addon manager.
thomas-neemann
saso wrote: Wed Jun 29, 2022 10:39 am ...
Thanks for the feedback
Chris_G
Post by Chris_G »
saso wrote: Wed Jun 29, 2022 10:30 am yes, and I also don't see it in other FC versions 0.19, 0.20 and I see no errors in report or console
What is the result of this command in the python console ? :
from freecad.Curves import FlattenFP
saso
Post by saso »
Chris_G wrote: Wed Jun 29, 2022 12:09 pm
For sure interesting! :)
ImportError: cannot import name 'FlattenFP' from 'freecad.Curves' (C:\Users\user\AppData\Roaming\FreeCAD\Mod\lattice2\.\freecad\Curves\__init__.py)
Update: so after uninstalling and reinstalling lattice, things are back to normal, but I have no idea how this happened. Thanks Chris for helping in solving this issue!
