Curves workbench
Chris_G
Re: Curves workbench
Post by Chris_G »
@edwilliams16 , is this working in the python console ?
progressbar = FreeCAD.Base.ProgressIndicator()
@hammax could you be more precise, because this is already possible to snap the points of a Freehand_BSpline to vertexes, edges or faces.
edwilliams16
Post by edwilliams16 »
Chris_G wrote: Sat Jul 02, 2022 9:33 am @edwilliams16 , is this working in the python console ?
No.
TypeError: cannot create 'N4Base19ProgressIndicatorPyE' instances
saso
Post by saso »
hammax
Post by hammax »
"@hammax could you be more precise, because this is already possible to snap the points of a Freehand_BSpline to vertexes, edges or faces."
... to be more precise - I felt sometimes, that there was something like snap - but with no real insight into procedure.
I will try it again with some "cheat sheet" copied from wiki, because the tooltip is too "small".
Syres
Post by Syres »
edwilliams16 wrote: Sat Jul 02, 2022 9:41 am
Surely that's nothing to do with Curves Wb but something packaging related?
edwilliams16
Syres wrote: Sun Jul 03, 2022 8:04 am
It fails with both earlier and the latest Mac Versions.
The only related failure report I found was https://github.com/FreeCAD/FreeCAD_Conda/issues/26. I can't tell if it was resolved.
OS: macOS High Sierra (10.13)
Version: 0.20.28909 (Git)
Hash: 6beef68ae1
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: C/Default (C)
Installed mods:
  * Curves 0.4.4
  * DynamicData 2.46.0
  * fasteners 0.3.44
  * fcgear 1.0.0
  * GDML 1.8.0
  * Help 1.0.2
  * lattice2 1.0.0
  * MeshRemodel 1.8919.0
  * toSketch
Version: 0.21.29393 (Git)
Hash: 6820e0a9ec85203a6f342ca72a2ff8fd417beaf1
Python 3.10.5, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * Curves 0.4.4
  * fasteners 0.3.44
  * fcgear 1.0.0
  * GDML 1.8.0
  * Help 1.0.2
  * lattice2 1.0.0
  * toSketch
It does work on the 0.20 Windows-64bit-Stable
EDIT:
Also in an Ubuntu 20.04.3 virtual machine on a Mac OK.
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, Vtk 9.1.0, OCC 7.5.3
Installed mods:
  * Curves 0.5.0
  * lattice2 1.0.0
hammax
Post by hammax »
... could it be a problem of the operating system?
microelly's NurbsWB had this "killer" flaw (Linux based).
Freehand BSpline would be an interesting tool, if handling would be easy, understandable and reliable.
E.g. snapping of 2 Freehand_Bsplines makes one of them uneditable/dead.
Trying to produce a Gordon-frame out of 4 or more is not possible.
Is there a possibility to edit the shown vertex coordinates - elsewhere they are useless.
Unexplained / unsolved flaws in the tool:
hammax
Post by hammax »
... using FreehandBSpline there must be learned some tricks and a certain workflow.
Besides up to now not all is intus. But finding usage of vertex table is a progress and helps over some irritations.
Next trial will be the "snapping procedure" and it's traps.
curve-network_6.FCStd
FC.20
(43.71 KiB) Downloaded 28 times
curve-network_5.FCStd
FC.20
(40.3 KiB) Downloaded 29 times
curve-network_3.FCStd
FC.20
(40.71 KiB) Downloaded 31 times
hammax
Post by hammax »
... snapping needs to learn the usage => after a lot of trials the snap and table usage gets stable results.
(and has sometimes it's own will !!)
Trying it with a kite sail.
- leading and trailing edge
- outer rim profiles
- testing on Gordon
- afterwards inserted inner profiles
Foil_Kite_4.FCStd
FC.20
(167.91 KiB) Downloaded 26 times
Foil_Kite_2.FCStd
FC.20
(42.08 KiB) Downloaded 28 times
edwilliams16
I'm not having much success with Surface|Flatten face. It works on cylinders and cones as expected - but not on the face of a Part Cube!
In the following file, the visible faces are developable - one is flat, the other is in fact conical, both created by Part Loft to a point, but I get Bad Input if I try to flatten them.
Screen Shot 2022-07-19 at 5.18.11 PM.png (15.37 KiB) Viewed 1466 times
recttotiltedcircle3.FCStd
(51.57 KiB) Downloaded 30 times
