Curves workbench
Re: Curves workbench
Great tool to build surface from 3 edges. Give something different with stretched/coons surface.
Clap clap clap.
Clap clap clap.
Re: Curves workbench - wrong update message
I wanted to update my Curves addon and get this update message:
Edit: This may be an issue with the addon manager, so please ignore it for now.
The update itself currently hangs, so I cannot tell what I get after an update.Edit: This may be an issue with the addon manager, so please ignore it for now.
an other try with gordon surface. Surface continuities are not very good like this.
- testcuis6cpy_vb.FCStd
- (159.36 KiB) Downloaded 22 times
- Capture.JPG (27.32 KiB) Viewed 1976 times
I have tried for too many hours and got poor results. I tried gordon and kinda works but not really. At least I learned a lot of the capabilities of Surfacing of FreeCAD... I will make my enveloppe with standard sketcher and part design without curves or surface WB. The curves and surfaces WB are too buggy and limited for the using I wanted. They just keeped crashing. constant crashing, at least 1 to 2 restart of freecad per hour needed. Ok for creating quasi flat surfaces like computer mouse or hulls but it is a big no for more complex shapes like the one I provided. A guy with master degree in mathematics or physics is needed to imlement minimal surfaces with variable pressure. The equation and algorithms are well documented in books for those who cant derive them. Zlibrary is the way to go, shame that governments tries to take them down ! Please Chris G, implement some minimal surface magic, please !
A new era of point programmation has come !
... if other tools are too complex, how about to learn and use Blend_Surface ?
- testcuis_3.FCStd
- FC.20.1
- (518.14 KiB) Downloaded 32 times
Thank you, It looks beautiful ! My enclosure is parametric and there are a lot of parameter, not sure if it will behave correctly. In my head I expected to have good surface out of the box with my original wire enclosure. I guess I have to make multiples lines, multiple gordon, multiple blend surfaces etc... Time consuming and often frozen requiring restarts. I prefer now to do it with sketcher. Tell me if you want some feedback on bugs encountered, because I am a noob so it is as if I stress tested the software, because noobs likes to click on buttons, but noobs don't expect software to froze.
Having created a JoinCurve from two lines and an arc in a sketch, I get the following warning when attaching another sketch to the JoinCurve:
What are the ramifications of this warning?
Problems later in the model?
AttachEngine3D::calculateAttachedPlacement: path curve second derivative is below 1e-14, can't align x axis.
It means that on the straight segments, the AttachEngine is unable to get a normal vector (to support the X axis of the sketch), since there is no curvature there.
I don't know the possible consequences, but I think it may lead to orientation inconstancies if you slide the sketch along the curve.
It depends on how AttachEngine finds a fallback normal when it can't get it from the curve.
Thanks.Chris_G wrote: ↑Wed Nov 23, 2022 1:58 pm It means that on the straight segments, the AttachEngine is unable to get a normal vector (to support the X axis of the sketch), since there is no curvature there.
